Convertible Top Question. It leaks, Halp!
  • Thread starter Thread starter AeFox88
  • Start date Start date Aug 12, 2011
A
AeFox88
28
NJ
Aug 12, 2011
  • Aug 12, 2011
Hey, the passenger side on my vert leaks pretty good. I first thought it was the clamp, but that's fine. Then I thought it was the dowel pin. All good. From messing with it I now think that the top isn't even. Basically, the passenger side looks like its pulling back a couple millimeters. Hard to explain, but when I push the passenger side top forward and then clamp it, it fits better, but still leaks.
When it's clamped down, I can't get my finger in to touch the dowel on the driver's side. I can on the passengers side and run it towards the drivers side until it gets too tight. Drivers side is good.
I'm thinking that because the passengers side is a couple mms off to the rear, it's not lining up properly with the top of the windshield and is hitting a piece of it so it doesn't close fully. I can see the marks of where the top was and where it is now. It needs to be adjusted forward...I think.
So, I'd like to know, how can I fix this? Or can I take it to a shop to have them adjust it?
I'll post pics in a couple.
A
AeFox88
28
NJ
Aug 12, 2011
  • Aug 12, 2011
First picture is the little rust where the top used to be. See, it's off to the back a bit.
Second is the passenger side windshield thing (durr) It looks like it's not pushed down all the way and is keeping the top from closing totally.
A
AeFox88
28
NJ
Aug 12, 2011
  • Aug 12, 2011
Maybe I can push that piece on the passenger side down and give it more room to close, who knows.
I really don't want to take it a top place and spend hundred to get it adjusted, but if I can't fix it, I'll just have to.
JungleJoe
I was like well chit..Im missing something
Jul 25, 2011
184
Mo.
Aug 13, 2011
  • Aug 13, 2011
I just looked on my brothers 92, his is just like yours(trim piece) and it doesnt leak. . . .
bwguardian
50
Houston, Tx.
Aug 13, 2011
  • Aug 13, 2011
The leaks typically occur where the door glass meets the windshield frame at the weather seal for the vert top...in that corner area. Is your leaking under the top weather seal between the windshield frame? I would first look at the weather seal front bow and see if you have any buldging from rusted staples since you are getting some rust on the windshield frame.
A
AeFox88
28
NJ
Aug 13, 2011
  • Aug 13, 2011
It leaks just a little bit on the passenger side corner. Nothing new weatherstripping can't fix. It's not the windshield, that's fine. It's basically the area where my finger is pointing in that picture. I know what's causing it, just need to know how to adjust it.
Damn 'verts :-(
JungleJoe
Jul 25, 2011
184
Mo.
Aug 14, 2011
  • Aug 14, 2011
So whats causing it?
A
AeFox88
28
NJ
Aug 16, 2011
  • Aug 16, 2011
The leaks? It seems like the top needs to be pulled forward on the passenger side so it matches up correctly with the windshield. I know where are some adjustment points on the top, but what's what? How would I just be able to move the passenger side up say...1/4 a inch?
Onefine88
Previously 89SSC18
1,422
796
154
Aug 16, 2011
  • Aug 16, 2011
Try readjusting the "J" hook on that side and run it in a couple rounds. That should snug it up tighter to the windshield frame. If that doesn't do it you need to replace the weatherstripping on the underside of the top.
Late Model Restoration sells a 5 piece weatherstrip kit for that top that will seal it off. You probably only need the header piece "which contacts the windshield" but I recommend buying the whole kit.
Most all the top adjustments are behind the interior quarter panel. You can move things around there although I don't recommend going there. It won't be possible to move the top forward as it will affect the fit on the rear quarter windows.
Replacing your weather strip will most likely solve your leak problems.
I've been there.
A
AeFox88
28
NJ
Aug 16, 2011
#10
  • Aug 16, 2011
  • #10
Weatherstripping is fine. It just doesn't close tight enough for the the weatherstripping to seal right. Jhooks don't do anything. Just rips up the receptacle. Basically, the windshield is in the way. Need to get it over the "hump"
Probably just going to take it to a shop if I can't adjust it. I was worried that one adjustment would throw something else off. Oh well
JungleJoe
Jul 25, 2011
184
Mo.
Aug 16, 2011
#11
  • Aug 16, 2011
  • #11
Like said above, those J-hooks move around a bit. . .
A
AeFox88
28
NJ
Aug 16, 2011
#12
  • Aug 16, 2011
  • #12
Oh yeah, I know. I took the whole clamp and dowel out and closed it without it. Same problem. :-(
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
Interior and Upholstery 87 Convertible Top dowel pin not lining up?
  • R82148V
  • Mar 8, 2024
3K
Fox 5.0 Mustang Tech Mar 17, 2024
R82148V
