Coolant Issues
  • Thread starter Thread starter 885.0conv
  • Start date Start date Jul 17, 2009
885.0conv
238
Phoenix, Az
Jul 17, 2009
  • Jul 17, 2009
Recently I have noticed that the temp of my car has been going up to 260-270 when idling or city driving, it will go down to 200 when on the highway. I noticed over the last month that the coolant in radiator keeps going low (which I am guessing why the temp is going up). I tried runing the car and checking underneath and pressure test but no luck. I just rebuilt the top end of the engine about 7 months ago (so new gaskets on top) but left stock cam in, put new radiator in about a year ago with new hoses and clamps, so I am guessing it is either the water pump gasket or timing cover gasket. I figured since I will be taking the pump off just going ahead and replace it. I wanting to get some opinions on some. Also if the may be a better way to test for a leak so I can save myself some time.
Thanks for the help.
WHT306
104
HUNTSVILLE AL
Jul 17, 2009
  • Jul 17, 2009
Had a similar thing happen to me it ended up being the timing cover gasket leaking at the block. I could smell it but could not find any on the ground until it got really bad. That was a fun sat afternoon job to do. Also check your pass floor board could be the heater core, coolant runs through those all the time.
GOOD LUCK
885.0conv
238
Phoenix, Az
Jul 17, 2009
  • Jul 17, 2009
+1 on the heater core but I replaced that last January. Looks like a fun afternoon ahead for me. Good idea to change the chain while I am in there, about 70K on the motor or should it be good for awhile?
WHT306
104
HUNTSVILLE AL
Jul 17, 2009
  • Jul 17, 2009
Yes i would definitely replace timing chain while in there with a good double roller, but only if that is the issue you are having.
885.0conv
238
Phoenix, Az
Jul 17, 2009
  • Jul 17, 2009
Any brand of timing chain better than the other, I figure I will bit the bullet and change it. My oil pan gasket is leaking a little and it has been at least 5 years, according to the guy I bought it from, since they were changed.
885.0conv
238
Phoenix, Az
Jul 17, 2009
  • Jul 17, 2009
I was also debating about getting an electric water pump. I was wondering can you run the pump with the OEM alt. and can you run it without getting an electric fan.
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
