Coolant leak
  • Thread starter Thread starter Rapid
  • Start date Start date Jan 31, 2008
R
Rapid
297
Columbia, SC
Jan 31, 2008
  • Jan 31, 2008
I have coolant seeping from the joint between the water pump and the timing cover, at the long bolt, furthest to the right, looking at the engine from the front.
Can I simply remove the bolt and use some thread sealer? It does not really pose a problem other than the occaisonal need to soak up the coolant every few days...
P
PJC Racing
199
  • Jan 31, 2008
If its comming from just around the bolt, removing it and resealing the bolt may work, may not.
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
Water leak from hatchback door
  • jeremyzcook82
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
jeremyzcook82
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
