Cooling hoses
Mar 20, 2009
54
After inspection my mechanic suggested that alot of the hoses, including any secondary, or bypass hoses. needed replaced. The ones I can see look pretty old so im guessing they might even be orginal. My question is, other than the obvious ones I can see, such as the radiator hoses, and the hose from the water pump to the t-stat, what other hoses are there and where are they located?
You can buy a kit from Summit that has every hose you would need to replace. They're all pretty much right there in front of you when you look at the engine. Unless of course you are referring to hoses other than cooling hoses.
any other hoses i should be worried about specifically on a 115k mile engine?
at the moment its my daily. and with school AND work i cannot be w/ out a car, espeically from something as stupid as a hose. would not be a good thing.
check the power steering fluid hoses for leaks and replace if necesary the main line for that system is under alot of pressure so any leaks will be pretty obvious just got done replacing mine
