Engine Cooling System Driving Me Crazy
jcgafford
1,114
95
104
Adrian, MI
Either it is working right and i am losing my mind or it is the water pump. When your car is up to operating temp is the upper radiator hose under pressure and what would happen if you took the radiator cap off? On mine it is never under pressure and i can take the cap off any time without spilling a drop. I even bought a new cap and used that... same thing. you can run it for hours and it never overheats and never fills the overflow. i did pressure check the cooling system a while back before i got it running and it held pressure fine. someone enlighten me before i rip off this water pump!
i am going to go through the whole thing again this saturday. pressure test system and cap. replace t-stat. and last replace pump. i actually did a block test a few weeks ago because i was worried about a head gasket leak, turned out to be fine. i will just repeat all the others again but i see myself ripping the pump out...
If your water pump isn't leaking and your engine doesn't overheat, you don't have a problem. At worst maybe your radiator cap isn't holding enough pressure. Even though it's new it might not be the right one for you, especially if you have an aftermarket radiator and the filler neck is slightly taller than on the OEM radiator.
Turns out it was more than a bad cap. the timing chain cover to water pump gasket was junk. changed that out this past summer and the hose is pressurised. Cooling system runs as it should. fyi that upper hose is supposed to hold pressure. if yours doesn't then there is a problem somewhere.
Three times. Finally read he directions and did it correctly the third time. pissed coolant out the driver side front of the engine. half a day of work and new water pump bolts and it is finally back to proper working order.
