Cooling System: Pressure Testing?
92Patrol5.0
1,076
Cedar Rapids, Iowa
Can you buy the tools necessary to pressure test the cooling system or do you have to go to a shop to have that done? I just want to pressurize the system to see if I can locate a coolant leak in the timing cover/waterpump area. Didn't know if you can buy the tools to pressurize the system or not?
I thought about that. But then I thought I might as well buy one if I can so I have one. Rather than having to go rent it everytime I use it. I did that with a puller when I changed my harmonic damper. I got everything back together and thought it was good. Took the puller back. Then the next day I found a problem and had to go re-rent the puller so I could take the balancer back off.
