Cooling system problems
  • Thread starter Thread starter stevesLX
  • Start date Start date Oct 1, 2007
stevesLX
373
cincinnati
Oct 1, 2007
  • Oct 1, 2007
O.K. my cooling system is all messed up and I can't figure it out. I replaced the thermostat and still no good results. Last weekened I had my to heater hoses diconnected from the firewall so I could get to my pressure regulator to change it out. Now I hooked the hoses back up and everyday I drove the car last week it would shoot up to 210-220 degrees. What happens is I go out start the car and no matter if I let it sit and warm up or drive it it only takes a few minutes and the temerature will rise up to about 180 and then start climbing from there. I pull the cap off and let it puke a couple times and refill it I get heat inside the car and the temperature drops back down to around 160 and everythings fine until you let the car cool down and then it does it again. So last night I messed with it some and I left the cap off of it and left it do its thing. It overflowed out a few times and then it bubbled up and started flowing like it should and I had heat and everything was great. I finished puting more coolant in and all of a sudden it was like a volcano went off it was spraying out of the radiator 3 feet in the air. I dont know what is causing this but I need to get it fixed. Any help would be appreciated.
rockytoohot
48
  • Oct 2, 2007
Sounds like a possible head gasket.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 2, 2007
  • Oct 2, 2007
I agree with rockytoohot. If you are shooting coolant out of the radiator then somewhere you are forcing a lot of air into the system.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
