Cooling system
  • Thread starter Thread starter 87'GTstang
  • Start date Start date May 12, 2004
87'GTstang
1,025
  • May 12, 2004
I was wondering how much pressure is supposed to build up in the cooling system? After running for awhile, my radiator hoses get pretty hot, enough to where the clamps "mold" themselves on the hose. The problem Is that after running awhile, there is so much pressure in the upper hose that you can't even squeeze it at all - is all this pressure too much or is it normal. Oh yeah, it overheats as well after 45 mins or so and doesn't drop.
beaver2489
503
st. joseph missouri
May 12, 2004
  • May 12, 2004
that depends on the radiator cap doesn't that?
It should say on the top of the cap...probably like 16-18lbs? also replace your thermostat, make sure your belt is routed properly so that the fan and water pump are doing its job. also, if the radiator cap is bad, it won't hold the proper pressure and you will get an overheating problem. for every pound of pressure, it makes your coolants boilng point so much higher...
P
PRO50SC
1,012
Olney, Maryland
May 12, 2004
  • May 12, 2004
Probly has a bad t-stat or a clogged radiator.
87'GTstang
1,025
  • May 13, 2004
Well I have been flushing and flushing the radiator and plenty of brown water keeps coming out lol. So I am using a strong flushing agent at the moment. The T-stat was replaced about 200 miles ago. The cap, I don't know what's up with that. The weird thing is that when it did overheat, the entire cooling system back flowed when and only at the instant I cut off the car. It completely filled up a near empty overflow tank and continued to overflow out of the dispense tobe and then on the ground for another 15 seconds after the overflow tank filled up. I don't know what to check next as i've never seen anything like this. The radiator is original with 267k on the odometer and a lot of things look abused or nearly-never serviced. Like I said though, The system doesn't have a lack of pressure, it almost seems to be too much pressure and by far. I don't know how the hose doesn't burst sometimes. Any additional ideas?
Z
ZERO-7
  • May 13, 2004
time for a new radiator. get every thing flushed out good before new radiator install
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
