Copper VS Platinum Spark Plugs
Which is better?
  • Copper Spark Plugs
    Votes: 15 65.2%
  • Platinum Spark Plugs
    Votes: 8 34.8%
  • Total voters
    23
You'll get a little more performance out of copper plugs, but they also wear out much quicker. With a supercharger you should run copper plugs and change them every 10,000 miles or so. However if you don't have a major power adder, then platinum will do you just fine and you won't have to change them nearly as often. So it really depends on what modifications you have as to what you need. Changing to a different style and heat range plug without having any modifications that require it will more than likely hurt you more than help you.
I have talked with a couple of race shops (Sean Hyland Motorsport and Houston Performance for instance) and they have said that these plugs are excellent for blower applications, SHM uses them on their race engines. They are a colder heat range for detonation control, and only cost $1.50 a plug. They've always treated me good
Unless you have a s/c or N2O run the motorcrafts that came with it...they are already plantinum and no need to spend more money on something that isnt gonna to increase your performance....unless your running screamin demon or MSD coil packs and wires...then its your choice!
Autolites are platinum as well and they are cheaper than Motorcraft.
bemol said:
I wonder if its good to fight detonation with a cooler platinum plug. Everyone suggests copper, is platinum that bad?
Cheers
Dan
Good question... I don't know about supercharger apps. All I know is that my setup is near stock and double plats came out of my car so double plats are going back in. I here that coppers are better performance maybe... but I don't want to change my plugs every year.
Changing the plugs isnt bad.. 30 minutes.. Tops. It's good to check on them every now and then anyway, especially if your hard on the car or drag race it. Coppers get the job done. I'd rather replace em and know they're fresh and ready to go than have platinums in there that are made to just last and wonder about them.
copper is the best conductor of electricity we currently have( besides super conductors) the reason why manufacturers put platinum tipped plugs in new cars is so you don't have to change them except every 100K miles..
for the 4.6 OHC(especally the DOHC) the plugs are so easy to change, it makes sense to go to a copper plug and change them out every 10K or so miles..
You seem to be a pretty good egg, so I'll be friendly.
There are numerous plugs that are 1 to 2 heat range's cooler if needed. Because these shops swear by them, does not make them the annointed King.
I have first hand experience with TR6's, and it was pitiful. My blown GT lost 30rwhp (dyno tested) with them. Changed to 764's and pickep up lost power.
I am not the only person to experience this. I am not sure if you know Edward Clark, who is part of SCT, he experienced the same thing.
All engines react differently with different combos, and in some cases the TR6's might work, so this becomes the plug of choice, others like mine, it was the msot awful thing I ever used.
Imagine going from 401rwhp to 429rwhp with just a change of plugs.
:stupid: Most intelligent post I've seen in this thread! And welcome to StangNet!!! :nice:
