  • 1994 - 1995 Specific Tech
Correct fuse 30 amp?
  • Thread starter Thread starter jzanelli7
  • Start date Start date Dec 11, 2008
J
jzanelli7
  • Dec 11, 2008
Which is the correct amperage fuse to use for the power seat,cigarette lighter, and lumbar support in my 1995 GT? It is the third fuse from bottom on the left side of fuse block. Is it 20A or 30A? Thanks.
HISSIN50
34
129
Dec 11, 2008
  • Dec 11, 2008
Looks like a 20 amper.
fusebox diagram
GTA_V6_Mustang
1,326
Miami, FL
Dec 14, 2008
  • Dec 14, 2008
for the cigarette lighter/accesory outlet/ power seat its 30 amp
HISSIN50
34
129
Dec 14, 2008
  • Dec 14, 2008
I just double checked a factory source and it noted a 20 amp fuse. Is your source reliable and is the factory literature known to be incorrect? I ask because typos happen (I don't doubt your source is better than mine) but I don't want to supercede a recommendation with a higher rated fuse (obvious fire hazards) without knowing it's bonafide good info.
GTA_V6_Mustang
1,326
Miami, FL
Dec 14, 2008
  • Dec 14, 2008
Yeah, my owners manual, lol. In the PDC in the engine bay.
HISSIN50
34
129
Dec 14, 2008
  • Dec 14, 2008
Interesting. I must not be understanding something. My owners (glovebox) manual, the Factory Service manual, Factory EVTM, and TMoss' schematic all show a 20 amp fuse.
I would stick with the 20 amper because we all know that it's easy to blow the circuit protection when a dime falls into the lighter receptacle. I would not want to run an extra 120-150 Watts of power through the wiring.
hotcobra03
poteet,tx
Dec 14, 2008
  • Dec 14, 2008
i might be way off here but is thier a 20 amp cb on starter motor relay? I do see 30 amp in never models in the battery junction box and a 15 amp in the central junction box?
94GTCoupe
1,412
92
79
CA
Dec 14, 2008
  • Dec 14, 2008
looking at the Chiltons book.
for 95 models.
the list says cavity #3 should be a 30 amp green in color fuse.power seat,cigar lighter.
but,the small diagram of the fuse box with the list shows a 20 amp fuse in the #3 cavity.
hotcobra03
poteet,tx
Dec 14, 2008
  • Dec 14, 2008
94/95 is the odd ball? Why so much on just that circuit for just 20amp? The info i had was before 94 and after 95 sorry
GTA_V6_Mustang
1,326
Miami, FL
Dec 15, 2008
#10
  • Dec 15, 2008
  • #10
yea as usual hissin is right its a 20 the 30 is for conv. top. I double checked the owners manual
J
jzanelli
#11
  • Dec 17, 2008
  • #11
Which fuse is correct?
Davis3 is correct. My Chilton and owners manual show the same mistake! The diagram in the books show a 20A fuse, but the description of what the fuse protects ( cigarette lighter, power seat, and power lumbar) reads 30A? The same typo is in both books. FYI I gambled and put the 30A fuse in and now the power seat and cigarette lighter finally work! Could someone please just look in the fuse block a see what size fuse is in that slot. NO manuals, NO diagrams just what amp fuse you have. Thank you.
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
R
Electrical Trunk Mount Battery and Cut Off Switch- Need Help
  • Rcdgl
  • Nov 20, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
nickyb
L
2012 Seats in 98 GT Convertible - pictures coming
  • lparsons42
  • Aug 11, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2025
lparsons42
L
