25thmustang
Mustang Master
First off I question the guy on that site, merely because he seems to half-*** list his mods. He spelled Edelbrock wrong, listed they just had a port and polish, and just seems to list stuff in random order. I am sure theres a ton of stuff he left out if thats really what the car is, but he lists his mass air meter, yet leaves out, the block, intake, cam, etc... Seems like someone with a huge mod list would mention the intake and cam hes running.
Second the stroker kit will make tons of power, but the stock block is the weak link at this point. Im sure he has an aftermarket one, but again, he didnt list it.
Raph130, a 347 stroker will NOT give you an instant 350 hp. You need the corresponding mods to go along with it. Strokers help when the motors built. I assume that what you mean, but again, wasnt stated. Noones doubting the power a combo like that can make, they doubt the 10.5:1 compression ratio, as supercharged cars dont take compression well. 10.5 is not a huge amount, but with 18 psi it is definately pushing it. I have seen guys run 10 psi on that much compression (not knowing it) and the car lasted for a few passes on 93 octane, before a head gasket went. If set up right and tuned its possible.
That much rwhp could run into the 9s and maybe 8s, with the right suspension and such. I know of a lot of 550-650 rwhp cars running in the mid 9s on small tires. Granted at that power levels to go even faster takes much more power. 50 hp at that level is only good for a tenth or two, whereas for us, that could be the difference between 14.6 and 13.9!
