Could it be?
  • Thread starter Thread starter 50foxbody
  • Start date Start date Oct 7, 2009
50foxbody
218
  • Oct 7, 2009
my car was converted from fuel injected to carb and my guages dont work except for rpm and speed. is the the reason none of the guages are working this is my first converted car thanks in advance
54deuce
106
  • Oct 8, 2009
If the under hood harness was removed that will affect the temp, oil, not sure about the volts I dont remember. The fuel gauge should work if I remember. I had to cut the plug end off the under hood harness and find out which wire goes to the gauges and hook them up seperately for a clean look.
HotFox
1,069
701
164
SE Michigan
Oct 8, 2009
  • Oct 8, 2009
I just went through this on my 92 a carbed car...I think on mine it was a red with white stripe and red with green stripe for the oil pressure and water temp if I remember. You will know it is the right wire when you ground the wire the gauge will go to max reading (I found them by elimination.), this will not harm the gauges. I just bought new senders from the local auto parts store.
Later I bought a wiring diagram online which is a good investment you may want to consider.
Scott
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Oct 8, 2009
  • Oct 8, 2009
(Near the driver side firewall)
On the Black Harness:
---(red/white 20ga) to the temperature sender.
---(white/red 20ga) to the oil pressure sender.
50foxbody
218
  • Oct 12, 2009
what if there is no computer installed could that be a problem?? i just found that out today i thought atleast the computer would still be in there.. i dont mean to ask dumb questions but i know nothing about carb. and im looking to learn thanks
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Oct 13, 2009
  • Oct 13, 2009
Not dumb at all
Most people just yank out their computer, or just simply disconnect it and don't bother removing it from the kick panel.
50foxbody
218
  • Oct 13, 2009
o so that wouldn't be the problem then?
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
