  • 2.3L (N/A & Turbo) Tech
??? Couple Questions ???
  • Thread starter Thread starter IslandBlueStang
  • Start date Start date May 20, 2004
I
IslandBlueStang
24
  • May 20, 2004
I have low oil pressure according to my gauge?
What does that mean? Bearings, or oil switch?
What can i do to fix it?
IS it a bad thing to drive around with low oil pressure according to the gauge?
THanks again,
IBS
Lex
248
Halifax NS. Canada
May 20, 2004
  • May 20, 2004
I just had my Oil Pressure Sensor replaced 2 days ago because I barely had pressure showing on the gauge, I knew though it was an OPS because It was leaking oil out of it too. I would do a Pressure check first to determine if it is a sensor or something else like the bearings, oil pump, etc...
Cost me 20 bucks.
JamesBaumann
624
Vancouver Island
May 21, 2004
  • May 21, 2004
You could look at a new oil pressure sending unit, or a new switch. However, from what other have told me on this forum, these oil pressure gauges on these cars are basically as good as an on/off switch. You either have some, or you don't, they are not very accurate at all. As a matter of fact, here is the link to the thread that I started just last week. http://forums.stangnet.com/showthread.php?t=462404&highlight=Oil+Pressure It turns out that my oil level was just low. I hadn't checked it in a while because I figured it would be fine, I knew I wasn't leaking it and I knew I wasn't burning it, but somehow I lost some. Anyways, thats not important, hope this link helps.
140cilx
2,385
GA
May 21, 2004
  • May 21, 2004
I'd replace the sending unit on the driver side back of the head. That is most often the problem.
I
IslandBlueStang
24
  • May 23, 2004
thanks lots of help
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
