Couple questions
  • Thread starter Thread starter uneverkno
  • Start date Start date May 11, 2006
U
uneverkno
65
  • May 11, 2006
i just picked up a 93 gt (All stock)and i have a couple questions. where does the vacuum hoses under the upper intake go? when i got it there was none on them. also the starter is sticking on it after its running. ive changed the solenoid, so what could it be? ignition? also how do i go about adjustiong the clutch? any and all info is greatly appreciated
HISSIN50
34
129
May 11, 2006
  • May 11, 2006
The starter could be a bendix that's hanging up.
Though a little different for your 93 compared to an 88, here is one diagram and here is another diagram.
If you have a stock clutch quadrant/pawl, pull up on the clutch pedal. If not, post what you have.
Good luck.
wild86stang
115
Milan, OH
May 11, 2006
  • May 11, 2006
Although Hissin provided diagrams, to quickly sum up the vaccum: Fuel pressure regulator, EGR valve, PCV valve, vaccum tree, and the charcoal canister. I think thats all of them.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
