crank bolt size?
well then 31/32". :)
i thought it was 15/16 too. i seem to recall using an SAE socket (I think). are you sure there are no burrs on the bolt, which are keeping the socket from goin on?
good luck.
if someone (not you) was rotating the motor and too lazy to use the right sized socket (using a 1" or 25mm, etc) they might have rounded the bolt edges a bit.
good luck.
type911 said:
Tried the 15/16s again and I must have been have a sleep. It fit fine. thanks guys. :bang:
just like us, sometimes the tools want to rest - they choose to not fit or fight you when this happens (sometimes they will run away, so you cant find them). :)
glad you got it.
