I'm in the process of aquiring parts and info on building a stroker motor. The one book I've read basicly says to test fit everything twice, then recheck your clearances again. Most things like girdles and scrapers have to be modified for the longer stroke and larger counter weights. DId you contact the canton or the stroker kit builder? Perhaps you could mock the short block, put a few bolts in the pan an turn the motor over slowly by hand an listen for interference. Good luck with it.
