Crank, No Spark Help!!
  • Thread starter Thread starter Mike Boucher
  • Start date Start date Nov 18, 2017
1 of 2 Next Last
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 18, 2017
  • Nov 18, 2017
I'm a new member, but have been combing the forum for ages. Especially lately. I'm very familiar with jrickners "crank no start" checklist, but my mechanically challenged self is either missing what I should be seeing as the culprit or my car is possessed.
Here's the details that might be pertinent. 86 Mustang, 347 SC, mass air converted, t-rex ext. FP, in tank 255 FP, 8456 MSD pro billet distributor. Car ran fine for years like this, but a couple weeks ago started initially, stalled, cranked forever, started one last time and now nothing. When I crank the car, it cranks fine, gas gauge drops, volts on batt. gauge drops to 0, which I don't think is normal either. I don't remember if it did this prior.
I've already replaced the AFPR, coil, ignition switch, ignition module, tfi module, fuel; filter, ECM relay, the FP primes with key in "run". I got power from the yellow wires on the ignition switch, but none from any others. I've checked/cleaned all the grounds, have 40 psi at FP gauge that holds. Initially the FP went up to 40, then dropped like a stone regardless of if the car cranked or not. Hence replacing the AFPR. I've also cut the 20 gauge and 18 gauge fuse link to replace, and replaced the 14 gauge fuselink.
Sorry for the long post. I'm just about to put a match to this thing.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 18, 2017
  • Nov 18, 2017
I'm not getting spark at the coil, plugs, distributor or anywhere else.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Nov 18, 2017
  • Nov 18, 2017
To me it sounds like you may have a power distribution problem. Time to go after it with a multimeter.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 18, 2017
  • Nov 18, 2017
Got it and if you have any suggestions on where to start, I'll get after it as soon as I get my news fuse links arrive. I would have bet on it being the ICM, but no dice.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Nov 18, 2017
  • Nov 18, 2017
Yeah you mentioned not having power and replacing the ignition switch. Do this as a first test.
Also the no strart list is quite good... if you followed it step by step the car should be running.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 18, 2017
  • Nov 18, 2017
Yup. Put in two different ignition switches. Have power to the MSD box, but none coming from it, so none at coil. I'll look at the check list again, but think I saw that if you have power from the yellow ignition switch wires, but none at the brown/pink, red/light green, you should change ignition switch. Then, if no spark at coil, the 20 gauge fuse link has probably blown,.
Am I missing something or reading next steps wrong?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 18, 2017
  • Nov 18, 2017
Use of the search function would have brought up this gem...
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 18, 2017
  • Nov 18, 2017
I found a second ground strap, by the bolt that grounds the braided strap to the firewall and am assuming that's my problem. I won't know until I get the fuselinks installed again. It's a big ground with a wire running into it. Any idea what it's for?
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 19, 2017
  • Nov 19, 2017
Still won't start.
General karthief
Mod Dude
Aug 25, 2016
28,100
10,714
213
polk county florida
Nov 19, 2017
#10
  • Nov 19, 2017
  • #10
Can you get us a pic?
Never assume anything on a car, you'll waste time and money.
Make sure your battery and starter are turning the engine over fast, a slow cranking engine is hard to start.
A quick way to check whats wrong is to give it a quick shot of starting fluid, just a quick shot, if it trys to start then it likely will be fuel related,
If you start at the top of the no start check list it will cover every possibility of a no start situation. Including ground connections.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 19, 2017
#11
  • Nov 19, 2017
  • #11
I'll see if I can grab a pic now and I tried TB cleaner early on to see if fuel delivery was the issue and nothing. I'm bummed. I thought the ground I found was the answer. It's definitely a spark issue, maybe fuel as well and I was convinced it was the FP early on. I'll go back to the start and try the list one step at a time. Now if you'll excuse me, I'm about to stick my head in the microwave :-(
Reactions: General karthief
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 19, 2017
#12
  • Nov 19, 2017
  • #12
It's cranking strong. Have a fairly new Optima yellow top.
General karthief
Mod Dude
Aug 25, 2016
28,100
10,714
213
polk county florida
Nov 19, 2017
#13
  • Nov 19, 2017
  • #13
I know that microwave feeling, only it was small children and dogs,
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Nov 19, 2017
#14
  • Nov 19, 2017
  • #14
Ok so do you have spark?
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 19, 2017
#15
  • Nov 19, 2017
  • #15
Nope no spark at plugs, coil or distributor.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 19, 2017
#16
  • Nov 19, 2017
  • #16
It looks like the ground I found disconnected was the HEGO ground.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 20, 2017
#17
  • Nov 20, 2017
  • #17
Back to the checklist:
Don't bother with the fuel section at this time. No spark is where the problem is, so stick with that until you have spark
Do the first section of the checklist and check for voltage at the ignition coil with the ignition switch in the Run position and crank the car. Cranking the engine without having the ignition switch the Run position means no voltage at the coil; that is by design.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 20, 2017
#18
  • Nov 20, 2017
  • #18
Got it and will do. When you say crank the car with the ignition switch in the run position, you're saying use a jumper wire from the push on solenoid connector to the positve/big bolt on the solenoid, correct? I'm not supposed to crank with the key, right?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 20, 2017
#19
  • Nov 20, 2017
  • #19
Either way that is convenient.
Just remember that if you jumper the starter to crank the engine, there is no power to the ignition coil or computer unless the key is in the Run position.
M
Mike Boucher
Active User
Nov 18, 2017
52
Nov 20, 2017
#20
  • Nov 20, 2017
  • #20
Got it and thanks for clarifying.
1 of 2 Next Last
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • dan50
  • Jul 18, 2026
dan50
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
