The #3 cap thrust bearing is completely wiped out down to the copper on both sides of it, but mostly the rear of the thrust bearing is completely scraped clean of any bearing material it once had, and also scarred the crank in that spot, does anyone know why this happened the rest of the mains and rod bearings are in bad shape too, especially for being "freshly rebuilt"...but none as bad as the sides of the thrust bearing, the crank was turned .010 under and they didnt chamfer the oil holes so they marred the bearings..same with the rod bearings, thanks for any help
~Mark~
~Mark~
I really need an updraded clutch though cuz my clutch slips when at the track.
