Crazy Thing going on
93SteedaStang
Ohio
So I just got this crazy problem, I just got my car running with the new cam and it started fine ran fine for the first week. I took it out to drive it an it was fine as well but when i was putting it away it just died. now the only way i can start it is with ether and have the fuel pump disconnected . i got spark, i got fuel and there's plenty of air. when i plug in the fuel pump and theres pressure the car just dies. after like two minutes of running i plug in the Fuel pump and the car runs really rich. The only thing that i have to fix is the TPS voltage the idle screw has been moved i dont think that would mess anything like that.
I have checked the injectors, they work fine, got 12v to the injectors the only thing that i notice was that it runs rich even with my chip (old tune before the cam).
mods:
302
Cobra computer
HCI
Supercharged
E303
A1000 Fuel pump and rails and Press Reg
42# inj
90mm MAF
MSD ignition
Ive tried lots of things , running no belt on the SC, No Chip, Fresh fuel.
Am looking for a analog tester to see what codes it throwing,
need help please.
size=3]Dumping the computer diagnostic codes on 86-95 Mustangs[/size]
Revised 18-Mar-2011 to advise differences in code information for engine running and engine off codes.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
