cross drilled rotors cut in North NJ or South western NY
I'm looking to find a place that will resurface/cut cross drilled or slotted rotors in Bergen county NJ or Rockland/Orange/Westchester county NY. Alot of places won't do it as they fear it'll wreck the bits on the lathe machines. If any one has had success getting them resurfaced in that area let me know. These rotors are too expensive to throw away.
thanks
thanks
It would probaly be cheaper to get a set of ebay rotors.
I did a group purchase on here years ago for RotorPros. If they are still around they made great well-priced rotors. Highly recommended from me. I'm still using my first set of Cobra slotted/drilled because I dont put many miles on my car.
Thanks for the input.
So nobody up in the NYC surrounding areas has any luck get slotted/drilled rotors cut?
This is for a '00 R brake set up. The two set of rotors I had worked very well, but I run through pads on these. I wouldn't wanna match $120+ pads with cheap rotors, kinda defeats the purpose. Resurfacing the rotors I already had would be my prefered choice if possible.
thanks again
thanks again
Ummmmmm, actually the rotors are made well, the only thing that quickly changes is the plating. If you get ceramic non-metallic pads, them suckers, especially the rears, will outlast your used rotors.
If you feel like taking a ride to Long Island NY(Bellmore) I got my baer rotors cut for about $25 a piece. They're drilled and slotted. The phone number is 516-221-5700(speak to Kevin) tell them that you got the number from Kendoo. The name of the place is Parts Authority.
