Crossmember brackets
  • Thread starter Thread starter rd
  • Start date Start date Apr 24, 2007
rd
3,316
63
109
Ocean Springs MS
Apr 24, 2007
  • Apr 24, 2007
I need to install a double hump crossmember on my 79, as it has the older narrow style.
What is the easiest way to do this?
I'm thinking just fab a new rear bracket and cut the originals off.
Is there an easier way?
I am installing new exhaust and an AOD that needs the trans bolt holes further to the rear.
Thanks.
K
krallman
96
Hurricane, WV
Apr 25, 2007
  • Apr 25, 2007
is the crossmember tack welded on the two tubes that go inbetween the mounts already. I just put a c-4 in my 85 and i had to grind the tac welds off then scoot the crossmember all the way forward then tack the cross member on the tubes again. I dont know if you have tried that or not but if you have then you have to cut the mounts and move them back.
tbovee
129
Fredericksburg Va
Apr 25, 2007
  • Apr 25, 2007
The '79 mounts are too narrow and too far forward. I fabricated a mount from
2" square tubing and the round (bushing) ends from the old cross member and attached a bracket in the middle for the trans mount.
  • dan50
  • Jul 18, 2026
dan50
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
