cutting out at 4k and up!!!
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
yo, first of all my 86gt, has gt40p heads, tmoss intake and a b cam, 65mmtb and a full exhaust with a 255lph pump and other little things. Anyway it was running great the other day so I went and filled it up at an inland station, long story short, there gas is mixed with like 20% or 10% something like that, well I take it out for a drive and it starts knocking and idling at like 2k!!! Has no power and is getting hot, well I smoked a plugwire, and the idle motor is stuck open, so no big deal, I put another plug on and unplug it, and turn the timing 2 deg's back, I drive it today and it runs great up to about wot, but once you put it down it starts cutting out, no knocking just this loud BLAHHHHHDDDDD deep throatty sound and no go, it actually gets slower and keeps busting up, I mean I can floor it from 1500 and it will pull from hell to 4k and then start this like "pop" then it pulls like hell for a second then will do it again and then pull to redline for a sec then I shift and it starts over again!! It feels like a small vac leak, but I cant find any!! HELP SAVE MY STANG!!! :bang: :bang: :bang: :bang: :bang: :bang: :bang: :mad: :mad:
Josh
TFI module failure mode is loss of spark at high RPM and a warm engine. Does this sound like what's happening to you?
If not, then...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
index.php
index.php
attachment.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
yeah ill try that, ill swap one on tomorrow, and see whats wrong, It only does it only when warm as well, so I guess i found the problem!! Does any parts store check these?
Many auto parts stores will check them. Bring along a hair dryer to heat the module while it is being tested. The modles tend to fail most when they get hot.
When replacing the module, clean the old heat sink compound off and use some fresh compound. If the auto parts store does not have heat sink compound , Radio Shack will.
