Hello,
Need some input/experiences with wheel spacers. I am thinking of putting 25mm (1") hub-centric spacers on the '94's rear wheels. It has chrome Ford 2000 GT wheels - the backside of the wheel hub (the area around the lug bosses) is flat (why that matters is below).
With 1" spacers, I would have to cut the stock lugs to the second thread from the end (around 3/8" IIRC). Otherwise, the lugs hang out past the spacers and hit the back of the wheel, obviously keeping it from seating.
Here is the thing. I know some folks cut their stock (axle) lugs down to accomodate this. But if I did that and wanted to go back to stock, the lug would not even go all the way through the nut with the wheel mounted (with no spacer, if I cut the lug). So basically, if I dont like the spacers or have issues, it seems to me that I would have to pull the axles and install 10 new studs.
Not what I would want to do.
I am hoping someone has encountered this and found some logical means around this issue. Or if were in the same boat and you cut away, let me know how it went and if you are happy. And all other ideas are welcome. I am not a spacer guy, so this is my first endeavor with these things; I keep seeing pics of guys with them (Andy, et al) and I want to toss some on there, but am worried about reverse-compatibility (or lack-there-of in this case).
Thanks for all replies!
I rememebered that you had to cut your lugs a hair (as do many folks). However, the 3/8" that I am lookin at [needing to cut] gave me second thoughts. Toss in my being a freak about reverse compatibility, and I had reservations. It looks like if I went back to stock (no spacer), I would have one or two empty threads in the lug nut!
I will be running some 315's out back, a la Chris.
