  • 2.3L (N/A & Turbo) Tech
Cylinder head ?
  • Thread starter Thread starter Rayzr
  • Start date Start date May 27, 2009
R
Rayzr
17
  • May 27, 2009
Yeah I have a 2.3t motor, the original head is no good. And I heard that I can use a cylinder head off of any 2.3 L4 engine, turbo or N/A. Is that true?
8svo6
  • May 27, 2009
A lot of people use carbed heads from 2.3 rangers. You want a head that has a combustion chamber that is between 60-62cc. It has to have D shaped combustion chambers as well. Also turbo exhaust valves.
J
j and v
34
nebraska
May 27, 2009
  • May 27, 2009
The D shaped combustion chamber isn't a requirement. If you use an open chamber head (heart shaped chamber), the compression ration will drop a bit. Equip the head with either the factory inconel exhaust valves, or at the very least some stainless steel ones. DO NOT use the standard duty valves. If the valves from your existing head are still good, take them to the machine shop with the head you're going to use and have them installed with a good valve job. Turbo heads are prone to cracking the castings through the exhaust valve seats. If you have minor cracking, you may be able to have your machine shop install valve seat inserts. When they do, they'll actually machine out the area that's cracked, and press in the new inserts. This is one way to pontentially save a head. You're machine shop should be able to tell you if it can be saved. May want to try more than one shop, depending upon their experience with 2.3T heads.
8svo6
  • May 27, 2009
or just throw down $1500 for bamf head
J
j and v
34
nebraska
May 28, 2009
  • May 28, 2009
Well, Rhea Performance are supposed to be releasing a new cast iron head soon. Supposed to flow pretty well out of the box. Or you could step to the Stage 3 Boport iron head package for $2000. Comes complete and ready to run. Bolt on and go. Faster.
babybudistmonk
70
Rockford, MI
Jun 3, 2009
  • Jun 3, 2009
or grab a head from the same car you have now at junk yard for $50 and have it tested for cracks. if it passes, and still want to go fast, its not that hard to port and polish. would just take a little time, but you could save a lot of money and still get better than stock airflow knowing it will fit.
J
j and v
34
nebraska
Jun 4, 2009
  • Jun 4, 2009
Yeah, sounds like a great idea, except 2.3Turbo motors don't grow on trees. The turbo heads used special exhaust valves to tolerate the increased heat. If you find one in the JY that's not cracked beyond usable, certainly grab it. But good luck finding one very often. Easier to find an N/A head and have it built properly, with exhaust seat inserts and the proper exhaust valves to deal with the heat.
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
gkomo
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
