Dash lights out........
  • Thread starter Thread starter 302RollinHard
  • Start date Start date Oct 11, 2005
302RollinHard
Columbus, OH
Oct 11, 2005
  • Oct 11, 2005
Just bought a 93 GT and none of the dash lights work. Where should I look to first-- bulbs?(don't think that all of them going bad is likely) or at the dimmer switch? The dimmer does 'work' e.g., it lets me turn on the dome light. Anyone else had this problem???? Thanks
jackchan
507
Mobile Alabama
Oct 11, 2005
  • Oct 11, 2005
strange!
I had the very same problem this morning!! my dash lights are out and my dimmer switch still lets me turn on my dome light as well. I'm hoping its a fuse or something simple. I hate wiring problems with lights etc...
let me know if you find your problem, I'll be searching mine out this afternoon.
Jack
302RollinHard
Columbus, OH
Oct 11, 2005
  • Oct 11, 2005
Not a fuse over here.......
It isn't a fuse on my end. So I have no clue. I have heard that the dimmer switches go bad in these cars, but not sure. hoping to get soem help here.
DTT92LX
185
Downingtown, PA
Oct 11, 2005
  • Oct 11, 2005
Check the connector on the back of the instrument panel. Mine had corroded connections. It was the connector on the right side of the panel when you pull the gauge cluster out. The contacts are pretty sketchy. Kind of like a computer card. It has those thin copper strip contacts. A little scuffing and mine lit right up.
darthcual
985
Arlington, TX
Oct 11, 2005
  • Oct 11, 2005
Havent had the problem but i believe you are correct about the switch going bad.
jackchan
507
Mobile Alabama
Oct 11, 2005
  • Oct 11, 2005
I've been putting off replacing my heater core but winter is coming and since my dash lamps are out I may just as well go ahead and do it all in one pop. I was also thinking of painting/dyeing a grey dash I have black, or just installing the grey dash while in there. I hate the arrangement ford had to replace the heater cores on the 87-93 mustangs.........dang retarded engineers!
Jack
Euphoric306
905
  • Oct 11, 2005
my dimmer switch works most of the time but sometimes when i switch the dome light off the instrument panel goes out, so i mess with the dim switch a bit and it goes back on... weird **** on your case, sorry nobody can help
dbdragracing
397
Oct 11, 2005
  • Oct 11, 2005
Subscribing....I have no dash lights either and my dimmer still turns the dome light on and off. My dash is out right now (due to replacing heater core) so I would like to fix it now.
DTT92LX
185
Downingtown, PA
Oct 11, 2005
  • Oct 11, 2005
What are you talkin' about?! I'm tellin' you, on mine, when only the gauge cluster was out, pulling the cluster and cleaning the contacts I mentioned worked! Try it. Only takes 1/2 hr to pull the pod and cluster and give it a shot. Feels pretty good when you have dash lights again...
Black Sun 5.0
1,337
L.I., N.Y.
Oct 11, 2005
#10
  • Oct 11, 2005
  • #10
Mad rash of dash light issues. I keep blowing the fuse on mine every couple of days. No clue what is blowing it.
big blue
132
lexington, ky
Oct 11, 2005
#11
  • Oct 11, 2005
  • #11
Same thing happened to me. It ended up being a problem with the dimmer switch. It has a different pathway to the dome light. 2 months of work to find the problem. Hope it helps.
Red88 RICK
101
Connecticut
Apr 2, 2007
#12
  • Apr 2, 2007
  • #12
On My car same thing as the first guy fuses are ok dimmer only turns domelight on/off but no dash lights only the signal lights on the dash and the 4 dummy lights
i tried pulling the cluster out got everything but couldnt get tot eh wires in the back to disconnect them it was liek to tight... so i just put it back togeatehr for another day
4G-KDMP
935
CA
Apr 2, 2007
#13
  • Apr 2, 2007
  • #13
if you release the speedo cable you'll have plenty of room to get to the wires.
Red88 RICK
101
Connecticut
Apr 3, 2007
#14
  • Apr 3, 2007
  • #14
oh thanks alot
mustangjoe87
364
Harrison Twp., Michigan
Apr 3, 2007
#15
  • Apr 3, 2007
  • #15
Somtimes mine go out and i have to screw with the dimmer switch to get them back.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Apr 3, 2007
#16
  • Apr 3, 2007
  • #16
There goes another question, "How do you release the speedo cable?"
I know how, but dang it is easy to forget between the times I do it.
I never touch my dimmer switch, I'm too afraid if I use it it will go out.
4G-KDMP
935
CA
Apr 3, 2007
#17
  • Apr 3, 2007
  • #17
there is rectangular looking clip on the speedo cable just push it down and it will release the cable from the instrument cluster.
RYC CUKR
1,437
Orlando
Apr 4, 2007
#18
  • Apr 4, 2007
  • #18
Just be careful not to pull the end off the speedo cable. TRUST ME, been there done that.
I have the same issues only I can sometimes get my dashlights to work by playing with the dimmer. I believe that the dimmer is the problem on almost all of the above issues. Over time it starts to degrade internally and won't allow the dash lights to come on or allow you to dim them. If I have my dash lights working and I try to adjust the dimmer they just go off. The dome light is just a set of switch contacts in the dimmer so there isn't as much to degrade over time. The only problem is that the dimmer is rather expensive and buying a used one is kind of hit or miss. I am just lazy and cheap and since my dash lights "work" I am gonna keep putting it off.
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
W
Headlights dimmer and gauges arent playing nice
  • wmfmike3
  • Aug 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
wmfmike3
W
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
