dash warning lights
fiveohGT
353
Fairfax Virginia
Because I swapped in my new radiator the low coolant light is always on. Does anyone know how to disable it for good? I don't use the sensor anymore.
Also, I deleted the airbag system. Does anyone know how to disable that light for good?
The low coolant sensor circuit needs to be closed to eliminate your warning light. When the coolant was low the circuit would open and trigger the light. You might be able to tie the wires together to eliminate it, but without a small amount of resistance in the circuit, it could also short out.
I don't have a car with an airbag so I can't help you on that one.
If it is in the lower right hand side of the instrument cluster then you can take them out. Pop the cluster off and there is a small box with the bulbs for those warning lights. Either take out the box or the bulbs.
