Dead Battery again!
kolson
mn
I have a 95 cobra convt. The battery keeps going dead after it sits for a couple of days. I checked alternator it was fine. Also checked light under hood to make sure was not staying on. If I do not pull the negative cable after driving the battery will be dead. Any ideas? Thx
Time to get out the wire wheel and start cleaning connections. Battery terminals, engine to chassis ground, battery to engine, back of the starter, underhood fusebox, etc. Anywhere that you have a source for corrosion to have built up in the charging system should get cleaned/checked.
