Dead Battery
  • Thread starter Thread starter TrophyHead
  • Start date Start date Aug 16, 2004
TrophyHead
1,195
11
49
PA
Aug 16, 2004
  • Aug 16, 2004
My car is draining my battery. I just got a Die-hard and after 2 days of not starting its dead.
The one day I pressed my horn too hard. Then it got stuck on so I had to pull the fuse, so it would stop honking. Could this drain a battery?
What's the first thing you usually check when this happens? Or what may be draining my battery?
Thanks for every thing.
87'GTstang
1,025
  • Aug 16, 2004
Look for electrical parasites like an underhood light not going out, couteousy lamps staying on, radio performing something it shouldn't with the key turned off and so on...................
TrophyHead
1,195
11
49
PA
Aug 16, 2004
  • Aug 16, 2004
Allright I'll check for lights and stuff staying on. It can't be the horn cause I pulled the fuse and that's cutting the power off.
I'll keep checking. I'm trying to figure it out now.
Anybody else wanna add anything feel free.
TheBocSez
652
Converse, TX
Aug 16, 2004
  • Aug 16, 2004
I recently had a similar problem. Turned out to be a bad Alt. It was grounding, causing a drain. I would park the car overnight and next morning it was dead. Got a new Batt and same thing. Easiest check is to use a digital multi meter on the batt. With the car off, you should get a reading of 12.6v, with the car on, it should be in the area of 13.5v. Recharge your batt and check it. If you dont have a multi meter, you can get on from walmart for 10.00 or take the car to your local parts store and have them check the whole charging system. Its free. At least you'll know whats going on or if thats where the problem is. Good luck.
HISSIN50
34
129
Aug 16, 2004
  • Aug 16, 2004
not saying it is the cause, but a bad alt diode will drain a battery overnight.
good luck.
MustangPunk302
1,051
West Michigan
Aug 16, 2004
  • Aug 16, 2004
If it acts like a drain it's most likely the alternator.. (assuming the battery is good and holds a charge)
I'm with HISSIN50 on this one..
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
