Electrical dead electronics
  • Thread starter Thread starter Kking
  • Start date Start date Jun 26, 2021
K
Kking
Hendersonville, North Carolina
Jun 26, 2021
  • Jun 26, 2021
i used jumper cables on my 89 gt and heard a pop and everything is dead not sure where to start looking the battery had just gone down from no use, i didnt ground to chassis
HemiRick
I'd be looking at jacking under the house
Jun 28, 2020
723
272
73
Memphis TN
Jun 26, 2021
  • Jun 26, 2021
see if any of the fusible links that come off the solenoid are burnt
Reactions: 68keyblr and Shakerhood
K
Kking
Jun 26, 2021
  • Jun 26, 2021
thanks checked them all and they have continuity ill keep looking
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Jun 26, 2021
  • Jun 26, 2021
So is the battery the problem? They were named Die Hard for a reason.
If you put the charger in 10a mode and have the clips connected to the cables (with one side off the battery), the older style (not digitally controlled and for AGM battery) chargers will have enough current to light up your dome light, probably the dash lights in the run position, and start testing for voltage with either a meter or a test light.
With the pop, did you see or smell the magical electric smoke? I still suspect a fuseable link, bad wire or ground.
Reactions: Shakerhood
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
