  • SN95 4.6L Mustang Tech
Dead Snake Help
  • Thread starter Thread starter McJ
  • Start date Start date Oct 14, 2005
1 of 2 Next Last
McJ
  • Oct 14, 2005
I went out to start my 99 Cobra the other day and the baby just cranked and cranked but did not start. Here's what I have done so far:
Engine spins. No DLCs
I checked for fuel and spark. Got Fuel, No spark
I pulled the Vortech chip, still no start
I checked the IAC, good,
I checked the MAF, good
I checked the Crank Trigger sensor Good
Cam Sensor good
Fuel reset fine,
All fuses checked good: in Engine Compartment and under dash (driver's side) are there any others???
Wiring appears good.
Any help???
Here are my mods:
BBK TB, Vortech S-Trim w/procharger cooler, Magnaflow, JBAs 4.10s, plasma boost.
I am just sick of my baby sitting in the driveway...
53BigDog
2,331
Palm Harbor, FL
Oct 14, 2005
  • Oct 14, 2005
No spark... maybe bad coil packs? did you check the other side too?
McJ
  • Oct 14, 2005
All 8 coils at once??? I checked all the cyls. No spark period...
Thanks for the input though...
McJ
  • Oct 14, 2005
Any help would be appreciated... I am really getting desparate. The wife's Geo is getting kind of sucky...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 14, 2005
  • Oct 14, 2005
Is the theft light flashing when you turn the key to the start position? Perhaps the PATS system has been activated...
McJ
  • Oct 14, 2005
I'll have to check that... How do you "De-activate? the PATS???
McJ
  • Oct 14, 2005
I'll have to check that. If the Theft light is blinking when the key is in the on position means that PATS has been activated??
How does one de activate the PATS???
I'll have to wait 'til I gethome to find out.
Thanks.
ponysarepretty
578
  • Oct 14, 2005
Theft light should blink every 2 seconds I think.
McJ
  • Oct 14, 2005
Just PATS??? Is there anything that may cause this problem?? I want to be running this weekend but... Pleeeease Pleeeease help... I can't even take it to a dealer... That's a real pain.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 14, 2005
#10
  • Oct 14, 2005
  • #10
Try just disconnecting the battery for 10 minutes or so...
McJ
#11
  • Oct 14, 2005
  • #11
Been there done that... No luck... That's the first thing I tried...
Thanks anyway...
ponysarepretty
578
#12
  • Oct 14, 2005
  • #12
Apparently its disabled by putting in your coded key, switching it to the ON position, not the start position, the theft light should come on for 3 secs then go out.
McJ
#13
  • Oct 14, 2005
  • #13
I'll check it out tonight... Thanks...
I have tried so many things I have no idea what's up anymore...
McJ
#14
  • Oct 14, 2005
  • #14
Finally home. I just checked the theft light. It is blinking when the car is off. When I turn the key to on (not start) the light stays solid for about 2-3 seconds and turns off. The car still will not start.
Any ideas?
53BigDog
2,331
Palm Harbor, FL
Oct 14, 2005
#15
  • Oct 14, 2005
  • #15
I thought the car was turning over just not catching right? That would eliminate PATS
McJ
#16
  • Oct 14, 2005
  • #16
So, if PATS was the problem it wouldn't even crank??? Well then it's not PATS...
Thanks
haneymotorsport
67
AZ
Oct 15, 2005
#17
  • Oct 15, 2005
  • #17
The engine will still crank over but not fire when the PATS activates. Just for sheits and giggles check your PATS key at the top of it. On the earlier Ford keys, the transmitter was placed in the top corner of the key with a small cap that was glued on to cover it. Alot of these earlier keys, they would fall off and the transmitter fell out. We sold alot of replacement keys until Ford had it molded/fused inside the key. You might also try your other key (if you have two). Sometimes the keys will lose their memory code. Just something that may help you before having to tow to the dealer.
McJ
#18
  • Oct 15, 2005
  • #18
Thanks for the input. Unfortunately, I have tried both keys. they appear to be intact and they do not start the vehicle. I'm still looking.
If it is a PATS problem how does one get by that to start the vehicle???
53BigDog
2,331
Palm Harbor, FL
Oct 16, 2005
#19
  • Oct 16, 2005
  • #19
Try the K I C K method. Step outside you car and kick it in its hind end! LOL - I think there is a computer reset that the dealer has.
McJ
#20
  • Oct 16, 2005
  • #20
Thanks I think the KICK method mightwork... At this stage I think I am about ready to try the DYNAMITE method!!!
I guess it's a call to the dealer...
Thanks again. I'll let you all know what happens if I figure it out. .
1 of 2 Next Last
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
