  • SN95 4.6L Mustang Tech
Dead topic (i know already!!) ???'s
  • Thread starter Thread starter stang09er
  • Start date Start date Feb 26, 2004
stang09er
115
Clarkston, MI
Feb 26, 2004
  • Feb 26, 2004
I am about to purchase the Accufab Plenum , but have a question about the throttle body. i curently have the BBK 70mm TB. Should i stay with it or bump it up to an accufab 75mm TB. Any input is greatly appreciated.
hognutz
1,940
albany, oregon
Feb 26, 2004
  • Feb 26, 2004
stay with the 70mm. the accufab actually loses airflow with the 75mm. flows 628cfm with 70mm and like 618cfm with 75mm.
stang09er
115
Clarkston, MI
Feb 26, 2004
  • Feb 26, 2004
Thanks a lot bro. I can spend less $$$ now!!!!
Will the screws mate well to my existing throttlebody??
BTW Hognutz...your stang is BADA$$!!!
stang09er
115
Clarkston, MI
Feb 26, 2004
  • Feb 26, 2004
nevermind.....i just saw your sig and you have the same TB as i do!!
C
clarkjr
716
NC
Feb 26, 2004
  • Feb 26, 2004
Actually, Accufab has just redesigned their plemums and they have a full 75mm opening, previously a 70. Thus, it should flow better with a 75mm tb. I think the new flow numbers are on their site.
stang09er
115
Clarkston, MI
Feb 26, 2004
  • Feb 26, 2004
Just preparing you all for a long post....here it goes!!
03Sleeper
464
Fordville,USA
Feb 26, 2004
  • Feb 26, 2004
Naw you will be Fine you only should go with a 75mm if you use a S/C so 70mm to a accufab Plenum will be fine..
stang09er
115
Clarkston, MI
Feb 26, 2004
  • Feb 26, 2004
FORD 1996 - 2004 4.6L 2V
STOCK 65MM
TESTED @ 5" - 248 CFM
CORR @ 20" - 496 CFM
CORR @ 25" - 556 CFM
CORR @ 28" - 588 CFM
ACCUFAB 70MM
TESTED @ 5" - 299 CFM
CORR @ 20" - 598 CFM
CORR @ 25" - 670 CFM
CORR @ 28" - 708 CFM
ACCUFAB 75MM - test results not available
1996-2004 4.6L 2V PLENUM FLOW RESULTS
5" 20" 25" 28"
STOCK PLENUM 1998 - 2001 ONLY 210 420 470 498
w 65mm Stock Mustang T/body 186 372 417 441
w 70mm Accufab T/body 207 414 464 491
w 75mm Accufab T/body 206 412 461 488
STOCK PLENUM 2001 & UP ONLY 213 426 477 505
w 65mm Stock Mustang T/body 194 388 435 460
w 70mm Accufab T/body 206 412 461 488
w 75mm Accufab T/body 207 414 464 491
Trick Flow Plenum Only 260 520 582 616
w 65mm Stock Mustang T/body 218 436 488 517
w 70mm Accufab T/body 251 502 562 595
w 75mm Accufab T/body 250 500 560 593
C&L Plenum Only 240 480 538 569
w 65mm Stock Mustang T/body 204 408 457 483
w 70mm Accufab T/body 235 470 526 557
w 75mm Accufab T/body 252 504 564 597
Dragon Plenum Only 280 560 627 664
w 65mm Stock Mustang T/body 226 452 506 536
w 70mm Accufab T/body 258 516 578 611
w 75mm Accufab T/body 261 522 585 619
ACCUFAB PLENUM ONLY 287 574 643 680
w 65mm Stock Mustang T/body 235 470 526 557
w 70mm Accufab T/body 265 530 594 628
w 75mm Accufab T/body 265 530 594 628
stang09er
115
Clarkston, MI
Feb 26, 2004
  • Feb 26, 2004
Yeahh...thats what I'll do. My engine has over 73,000 miles on it and i don't think it can take the amount of air induction that a S/C will produce.
C
clarkjr
716
NC
Feb 26, 2004
#10
  • Feb 26, 2004
  • #10
Personally, I too would stick with the 70 since you already have one. I was just informing you about the new plenums that are now 75mm.
Accufab told us a few days ago the flow numbers were, or were going to be soon, posted on their site - I've not checked - sorry!
stang09er
115
Clarkston, MI
Feb 26, 2004
#11
  • Feb 26, 2004
  • #11
Thanks.
hognutz
1,940
albany, oregon
Feb 26, 2004
#12
  • Feb 26, 2004
  • #12
thanks man. it will look alot better when I get it lowered next week.
it has yet to be seen on a stock car whether the 75mm accufab outperforms the 70mm. the preliminary flow numbers I have seen on it are identical. the data will be coming but I am having a hard time buying that much of a difference.
Accufab 70MM plenum only........619
with 70MM TB.............................628
with 75MM TB.............................614
Accufab 75MM plenum only.........680
with 75MM TB.............................628
hognutz
1,940
albany, oregon
Feb 26, 2004
#13
  • Feb 26, 2004
  • #13
that being said flow is no the end all when it comes to power but you are not talking 5hp here you are talking 1-2.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Throttle body
  • ShredThePred
  • Nov 1, 2024
SN95 4.6L Mustang Tech Nov 2, 2024
89ripper
