Detroit locker working properly?
  • Thread starter Thread starter squidz
  • Start date Start date May 15, 2009
squidz
22
  • May 15, 2009
The other day I was breaking in my new tires, was doing some burn outs. I was laying rubber only with the driver side rear. I checked the rear tire pressure and they were both the same psi. Is there something wrong with my detroit locker?
Bullitt
Packin' Heat
2,743
Houston, TX
May 15, 2009
  • May 15, 2009
doesn't appear to be working. You should hear a distinct "clunk" when it engages.
2+2GT
3,333
10
79
Southeastern Pennsylvania
May 16, 2009
  • May 16, 2009
And an even louder "clank" when it disengages. That's why these never really caught on as factory equipment. Unless you were "into" cars, it sounded and felt like something broke when these went on and off.
You sure it's a Detroit Locker™? That's a very specific item. Ford used a few DL's, but mainly the Equalock™ on 64-68, and Traction-Lok™ on 68 up. In fact, the current Ford limited diff is a TL. The TL functions exacly the same as the GM Positraction™, using a wet clutch pack with a preload for minimum torque, and axle gear thrust to increase friction under load. Naturally, many things could have been added over the years, the DL is still in production.
squidz
22
  • May 16, 2009
yes this is a new aftermarket detroit locker. I added it when i rebuilt the rear.
2+2GT
3,333
10
79
May 16, 2009
  • May 16, 2009
Hoo boy, now it needs to be looked at professionally, to see if it's engaging. If it were winter out, I'd say find an ice patch, put one wheel on, one, and see if it engages. Could be a warranty issue, so don't let it go.
LUCAFU1
496
Tucson
May 26, 2009
  • May 26, 2009
i know you checked the pressure but that really doesnt matter. its how tall the tire is that is important. measure the height on each one to make sure theyre the same (they should be).
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 4:43 AM
manicmechanic007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
