  • 1994 - 1995 Specific Tech
Diagnostic Results
  • Thread starter Thread starter junkstang95
  • Start date Start date Feb 27, 2007
junkstang95
24
Tampa
Feb 27, 2007
  • Feb 27, 2007
My 95 Cobra has been surging while at low rpm's and as I start to accelerate. I can watch the rpm needle bounce up and down (+/-) 500-1000 rpm's at idle or while I'm accelerating or driving at a consistent speed.
I had a diag done at a local Ford shop and they said that my right side upstream O2 sensor was bad and my purge canister needed replaced.
Of course I'm not going to pay the $600 they quoted to have them fix anything I just needed a starting point to fix things myself.
Now, I replaced the right side pre-cat O2 sensor and I still have the surge.
Should I have replaced both upstream sensors while I was under there?
What is the purge canister and could it be related to the surging?
Any other suggestions?
Thanks in advance.
gcomfx.com
3,690
Republic, MO
Feb 27, 2007
  • Feb 27, 2007
http://forums.stangnet.com/showthread.php?t=687869
Unplug it... see how the car runs.
junkstang95
24
Tampa
Feb 27, 2007
  • Feb 27, 2007
I'll give it a shot.
T
tjh566
608
Northern Va
Feb 27, 2007
  • Feb 27, 2007
dont tell me even the ford comps think we have 4 O2's
junkstang95
24
Tampa
Feb 27, 2007
  • Feb 27, 2007
Not sure, all I know is that the diag results stated pre-cat O2 sensor which is where they're located. I didn't assume anything else.
HISSIN50
34
129
Feb 27, 2007
  • Feb 27, 2007
I don't see either of those creating a surge. The tach jumping suggests an ignition issue.
The purge cannister isnt even needed and it should not affect or create a surge.
Good luck.
junkstang95
24
Tampa
Feb 27, 2007
  • Feb 27, 2007
Thanks. Any suggestions?
T
tjh566
608
Northern Va
Feb 27, 2007
  • Feb 27, 2007
coil, wires, could be a few things.
HISSIN50
34
129
Feb 27, 2007
  • Feb 27, 2007
The PIP can also cause a tach studder - you'd likely feel a slight chug or shudder if the PIP is the cause.
junkstang95
24
Tampa
Feb 27, 2007
#10
  • Feb 27, 2007
  • #10
PIP?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 27, 2007
#11
  • Feb 27, 2007
  • #11
pip=profile ignition pickup, a.k.a. halls effect sensor or ignition module. The sensor on the bottom of the distributor.
Scott
HISSIN50
34
129
Feb 27, 2007
#12
  • Feb 27, 2007
  • #12
Don't ask for an ignition module if you need to replace a PIP - they will give you a TFI module.
Stator is pretty conventional nomenclature for a PIP - only if you find that you need one.
When a PIP totally craps its pants, you can use a DMM and check the wave coming from it - but with a slight burp there's no way a DMM can help. And anything short of an oscilliscope probably won't help.
HGFireHazard
460
Michigan
Feb 28, 2007
#13
  • Feb 28, 2007
  • #13
They do, or at least my local one does. I went there last Summer to get O2s before getting my S/C tuned and they asked me which ones I needed...
Come on now.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
D
SN95 V6 1994 occasional rpm surge while driving---where should I start?
  • DPP
  • Aug 30, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 5, 2026
DPP
D
