dial indicator
  • Thread starter Thread starter EmoryM
  • Start date Start date Aug 8, 2006
E
EmoryM
20+ Year Stangneter
May 22, 2002
25
  • Aug 8, 2006
I have a dial indicator from summit. How do you read it? It has small gauge in it that have numbers from 0 to 9 and I can turn the gauges that the 1to 100 numbers in it? I want to set the backlash on the ring gear
blkcobra50
209
  • Aug 8, 2006
The small indicator 0-9 tells you how many times the large indicator went around. one full circle on the large indicator is .100 inches. each little hash is .001 inch. So for example if the small indicator is between 4 and 5 and the large dial is on 50 which is .050" that would be a total of .450 inches.
R
Reed
78
BC, Canada
Aug 8, 2006
  • Aug 8, 2006
The gauges should turn so that once you set up the dial indicator and place the pin against one of the teeth, you can "zero" the reading and take a proper measurement.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 10, 2026
phil2001svt
