Front window issues
Hi All,
Hope someone has had similar issues. I have a 91 GT Hatchback.
Recently my motor has been making a skipping sound and intermittently isn't raising the window anymore. Also, I noticed the window not longer is closing at the top corner of the door frame, leaving a small gap for annoying wind noise.
I took apart the window motor and replaced the 3 cylindrical bushings. There were flat spots but none were broken. After pressing in the new bushings I noticed the larger plastic gear had a groove worn out where it connects with the worm gear. As it's going to take a week to get that part I decided to install anyhow hoping I could get it to work a little longer.
I loosened the 3 bolts that help align the window assembly, 2 near the front and the one at the top of door panel. Then I pushed the window up until it sat into the corner, closing that small gap. It took more force than I expected.
I then installed the window motor. I went to test it and pushed the button to lower the window and got a loud clunk, window didn't move, and the motor is now spinning freely.
1) Did I bind the window when forcing it to sit fully into the top corner?
2) Maybe it was on its last plastic tooth and the new plastic gear wouldn't have done that?
In case the window gap issue isn't an adjustment issue I've linked a video to the guide bushings as I rock the window. I think they look OK. I notice more play in the top bracket.
3) Thoughts on guide bushings?
4) Is the top bracket supposed to have that much movement?
Thanks in advance.
Bruno
Link to window bushing guide video
*Edit. Years ago I had the window motor walk off the window gear. I had to loosen the bolts to the window motor to set it back in place. Not sure if this history matters, but thought to add it just in case.
You're good here.
That window looks pretty tight to me, about that window motor, inspect the gear, look at the teeth on the window lift arm making sure it moves smoothly and is not bent, be careful, those windows are fairly heavy and will pin your pinkies very fast and it's painful, ask me how I know....
Those window motors were basically the same across the Ford line during those years. I have a box full of them if you need some visuals let me know
I had to replace both the gears in the power window motors in my 1985 Thunderbird (also a Foxbody). At first it was the driver door which makes sense as we use that one the most. When I removed the old gear it was in pieces. You can get replacements everywhere but don’t pay more than this:
I used silicone grease to pack the gear housing as I had to clean all of the old stuff out as it had all kinds of plastic pieces in it.
Once you get the window motor operating like it should then you may indeed need to adjust them.
Not fox body specific, but I have experience with classic car window tracks. You shouldn't have to jam the window up into the door frame, it should go fairly easily into position. So it does sound like it jammed up after you "aligned" it manually, and then blew the gear apart due to resistance, age, and weakness of the part.
Check the window seals and felt in the upper part of the door. It may not be that corner that is the issue, but rather the front of the door frame by the A-Pillar. Maybe something is pinching or got bent at some point and is causing the binding.
Could also be that they are really dirty. Happen led with the rear door glass on my daughters Altima. Had to completely disassemble the doors and pull the glass out to remove the felts and clean them. Worked like a champ after that.
Looks like the new motor gear worked to help seat the window correctly. Ill test it on the freeway later this week. Thank you for all the help!
Random question. How do you all deal with mosquitos? My parking space is near our water heater tank and it always had mosquitos near it since it was installed. I get eaten alive!
Edit. I spaced and slightly stripped 1 of the 3 the bolts that hold the window motor to the door. Is there a "good enough" diy fix, like blue locktite, or something I can squirt into the threads that recreate threads when I screw the bolt on?
