  • 1994 - 1995 Specific Tech
did a break my input shaft?
  • Thread starter Thread starter Daniel50
  • Start date Start date Jan 26, 2007
Daniel50
716
Discovery Bay, CA
Jan 26, 2007
  • Jan 26, 2007
so i get a bad vibration in the car at 4k rpm's to redline. you can really feel it hard through the shifter. the motor mounts and tranny mount were just changed after i felt this vibration. so that wasnt it. it does this in neutal and with the clutch in so i know its not the driveshaft. the motor does not shake at all so i know its not the motor. would this be the input or the output shaft? this all happened when i went to downshift from 5th to 4th and it started to do it when it hit 4th. does this is every gear
bill302
2,131
alabama,gadsden
Jan 26, 2007
  • Jan 26, 2007
have you checked the balancer...i would ensure the balancer rubber section has not tore or slipped.
chaos254
467
NJ
Jan 26, 2007
  • Jan 26, 2007
my car does the same exact thing and I haven't been able to figure it out. I'm assuming its the tranny itself(shaft might be bent? flywheel? i have no clue lol).. I also replaced the driveshaft, motor/tranny mounts, balancer after this happened and none of it has fixed the problem. It's been like this for awhile now.. let me know what u find! Does your shifter shake when your idling as well?
DDSTANG94
465
FRASER, MICHIGAN
Jan 26, 2007
  • Jan 26, 2007
PIOLT BEARING, BLOCK RING, NOT SURE ON ETHER BUT I WOULD THINK YOU WOULD KNOW IF YOU SNAPPED THE INPUT OR OUTPUT SHAFT
99FiveOh
2,051
20
99
J-Ville, FL
Jan 27, 2007
  • Jan 27, 2007
seems to me if the input shaft doesn anything, it will snap in two and the car won't move. I'm having a similar vibe problem and I'm suspecting my clutch. I will know for sure soon. I'm thinking a piece of the disc might have broken off and thus causing an imbalance, that or the pilot bearing is messed up.
N
Vibration after new clutch
  • nipple_looker
  • Sunday at 4:18 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 12:05 PM
fasterthangas
F
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
