Difference in stock cams??
  • Thread starter Thread starter The Shape
  • Start date Start date Apr 6, 2005
The Shape
2,224
East ARKANSAS Delta
Apr 6, 2005
  • Apr 6, 2005
I have an extra engine out of an '89 GT, so it was of course mass air. My car is an '87 and I am still running speed density. I am just wondering if the cam from the mass air motor will still work fine with my SD system? I have heard the SD cams were a bit more agressive than the stock mass air cams and I have heard they are the same. Which is true?
I am just checking the compatibility of my spare parts.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Apr 6, 2005
  • Apr 6, 2005
have a look
The Shape
2,224
East ARKANSAS Delta
Apr 6, 2005
  • Apr 6, 2005
Thanks grover. Not being very educated on cams I can of course see they are different. But does that mean the sd is a bit more agressive? And will the '89 cam still work ok on the SD? Apreciate the chart Grover just saved it on my hard drive, but can you explain the difference in the cams to me as if I were a two year old? LOL
shttygtstang
978
  • Apr 6, 2005
well here what i know and i hope i can help . sd cars can use maf cams but without a maf conversion they wont run right .
When your looking for a cam for a sd car your verry limted there are not to many made . other will chime in im shure but if you wanna runa maf cam out of a 89 up you must have a maf sytem
90_Red_LX
668
Asheboro, NC
Apr 6, 2005
  • Apr 6, 2005
Why in the world would you swap a 89 stock cam in? Not following you on this one. If it was me, if I rip it down to put a cam in, you can bet your @$$ it won't be a whimpy one.
The Shape
2,224
East ARKANSAS Delta
Apr 6, 2005
  • Apr 6, 2005
Not planning to swap the '89 cam into my engine. I have the whole complete running '89 engine I picked up as a spare. I am just trying to figure out if I was to drop it in a run it with my SD if it would be ok.
Speeds8erM-1
1,240
Pensacola Florida
Apr 7, 2005
  • Apr 7, 2005
The speed density wouldnt notice that small of a change Im sure. Otherwise it wouldnt run worth a d@mn with 1.7 rockers on the stock cam and they run fine.
HISSIN50
34
129
Apr 7, 2005
  • Apr 7, 2005
James, if you did that, the numbers would not match and the folks at the shows would notice that when voting.
R
Ray@VSK
355
  • Apr 7, 2005
Hey Grover I don't know who made that chart but almost every cam spec listed on there is wrong.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Apr 7, 2005
#10
  • Apr 7, 2005
  • #10
It could be wrong, i dont know it was in an old mag years ago
The Shape
2,224
East ARKANSAS Delta
Apr 7, 2005
#11
  • Apr 7, 2005
  • #11
Yeah Yeah
R
Ray@VSK
355
#12
  • Apr 7, 2005
  • #12
The stock mustang cam specs are close but one I do know for sure is the 90-93 lca "lobe seperation" is definately wrong.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 7, 2005
#13
  • Apr 7, 2005
  • #13
Actually you don't know what you've got in a stock cam unless you degree it. EDC has stated that they vary in duration in about a 204-212° window. Mine fell just outside that on the intake side - 219I/212.5E @ 112.5° lobe centers.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
