Could anyone give me a list of the differences in these cars? Not just engine , but also the styling.
ChrisXoxide said:Could anyone give me a list of the differences in these cars? Not just engine , but also the styling.
99SVTAddict said:....different transmissions, different wheel option (polished), 6-disk CD changer...that's about it.
lafear01 said:I also hear that the 01 snake is much more powerful than the 99 slug...
OH....and you forgot that the 01 has the 31 spline axles...![]()
STUD said:99 SLUG. I have a 99 cobra with 300rwhp(sae) and no porting, no headers and no inner fender cold air kit. As soon as I add a WMS inlet pipe, velocity tube and 90mm lighting mass air, I should be at 310rwhp. Nazman has a 99 cobra with 330rwhp(it's a factory freak). Watch what you say. My car was tuned by the best, steve @ www.powertraindynamics.com. It pulls like a racehorse on steroids. 99 cobra's are just as good as the 01's after the fix. Bob Cosby's 99 cobra is a testament to that.
Later
****!........................i've been converted!
you.
Hey 103,that's a lot of HP for just bolt-ons and no cold air kit. Tell me what your bolt-ons are, and maybe post a dyno sheet. The most HP I've read about on a NA cobra is 330 by NAZMAN. He's got headers, port/polished intake, electric waterpump, and full WMS cold air kit, and more. He has a factory freak. Bob cosby's 99 is putting out 312 and he has headers and denscharger cai and more.103 said:I make 320 rwhp and I have nothing but bolt ons. I still even have the stock airbox--it's just cut to have a bigger opening. Plus I have a TKO which absorbs more power than the T45 or 3650. No real point, just bored.
54life said:WHOOOAAA 99 slug???? You better rephrase that. They are by no means slugs. I would go with the 2001 solely for the seats and the headlights. The dyno sessions that I have witnessed showed very minute differences in the two engines. The 2001 is better for the minor things not the engine.
Those BBK LT'S really gave some power, I wonder if I could put up 20 more HP with BASSANI mid lengths. My uncorrected numbers were 311rwhp,maybe 325-330 with headers. Is it worh it, probably not, but who knows.103 said:oye, here ya go... BTW, my numbers are uncorrected on a Dyno Jet. That day, however, the SAE numbers were within five hp of Standard numbers. The car was dynoed at Lugens in Miami. And I don't have the graph scanned or anything... I suppose I could get a roommate to put it up if you really, really want it. Also, the TKO robs more power through the drivetrain than the stock tranny. So the numbers would actually be higher with a T-45 or TR3650.
BBK LTs
Bassani O/R X
MAC 2.5" cat-back
Steeda pulleys
Homemade intake tubing (3.5 inch exhaust tip between cut stock elbow and stock MAF. Cut airbox for clearance and flow with K&N replacement)
PCV delete
TKO (with SPEC Stage 3 clutch, stock cable assy, stock fw, and Pro 5.0)
Aluminum DS
4.30s (EDIT: forgot, it has a somewhat built solid rear)
Dyno tuned by SCT in Miami (reflash, netted five more peak hp and negative 5 ft-lbs, but the curves are better)
I think that's it...
Just curious, what octane gas were you running when you had it dyno'd. Will BASSANI midlengths work with a BASSANI catted x-pipe.103 said:oye, here ya go... BTW, my numbers are uncorrected on a Dyno Jet. That day, however, the SAE numbers were within five hp of Standard numbers. The car was dynoed at Lugens in Miami. And I don't have the graph scanned or anything... I suppose I could get a roommate to put it up if you really, really want it. Also, the TKO robs more power through the drivetrain than the stock tranny. So the numbers would actually be higher with a T-45 or TR3650.
BBK LTs
Bassani O/R X
MAC 2.5" cat-back
Steeda pulleys
PCV delete
Aluminum DS
