  • SN95 4.6L Mustang Tech
Differential Oil Type?
  • Thread starter Thread starter Twisted
  • Start date Start date May 22, 2005
Twisted
387
Hansen,CT
May 22, 2005
  • May 22, 2005
What type of oil does the differential take?
(I know it's 3.75 quarts plus 4oz of friction modifier.)
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 22, 2005
  • May 22, 2005
99+ takes 75W-140 synth
Twisted
387
Hansen,CT
May 23, 2005
  • May 23, 2005
anyone else? What brand is best? Redline, Amsoil, Royal Purple?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 23, 2005
  • May 23, 2005
Motorcraft is best.
05SonicBlueGT
36
Mississippi
Jun 7, 2005
  • Jun 7, 2005
A guy was telling me the other day that he has a new truck, and at the first oil change he put amsoil in his engine ,trans and rearend and rised his gasmileage 3 mpg.
SilverGTV8
295
West Brookfield, MA
Jun 7, 2005
  • Jun 7, 2005
I used Royal Purple. I put in 75-95, I didn't have the tag on the diff. :dunno:
I will be changing it in the next month or two and probably going with the 75-140.
R
rjstaaf
1,310
Somewhere
Jun 7, 2005
  • Jun 7, 2005
Actually the 8.8 holds a tad over 2 quarts. If you buy 2 quarts of fluid and the 4oz friction modifier that ought to be just enough. I bought a 3rd quart just in case I spilled some. If I could find it I would use Mobil 1 75W-140 but, most places don't carry it so I have been using Motorcraft's 75W-140. Just to save you the sticker shock, it is $17 per quart. I would also get one of those cheapy hand pumps in the gear oil section at the local auto parts store as it is a bear to get the new fluid back in without one. Make sure you have a tube of Permatex gasket maker for the cover. Make sure you clean the cover and the housing really well before you put the Permatex on otherwise chances are you will get a leak. The cover bolts should be torqued to 32ft-lbs and the fill plug 22ft-lbs. Give the Permatex about an hour to set-up before re-filling the housing. It is a 13mm socket for the cover bolts and you can just use a socket extension for the fill plug.
Here are the fluid specs.
Ford 8.8-Inch Ring Gear & Ford 8.8-Inch IRS
High Performance Rear Axle Lubricant SAE 75W140
Specification WSL-M2C192-A
Additive Friction Modifier C8AZ-19B546-A
Specification EST-M2C118-A
SilverGTV8
295
West Brookfield, MA
Jun 7, 2005
  • Jun 7, 2005
The diff will take 3 quarts if you have the FFRP girdle cover.
With royal purple you don't need the friction modifier, because it is already part of the formulation.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
SN95 V6 Mustang Tech Apr 30, 2026
badmech
