dipstick problem
I don't think you understand my block has a hole in the side of the block I changed the oil pan and sump to a front sump just want to find a dipstick to slide back into block that will read correctly do not want to remove and replace timing cover the engine just got rebuilt and painted and is already installed in car. I know I'm not the only one that has run into this problem.
I understand perfectly. Your choices are either modify the timing cover to accept the dipstick in the front or modify the suspension to accept a rear sump pan. Maybe others have a different solution.
