  • 1994 - 1995 Specific Tech
Direct Port Nitrous kit
  • Thread starter Thread starter badstang123
  • Start date Start date Jul 26, 2007
badstang123
397
Santa Clarita, CA
Jul 26, 2007
  • Jul 26, 2007
What do you guys think of the following kit on a pretty stock motor? They make the direct port for the Edelbrock Performer, which I have, and I thought it would be cool.
http://www.holley.com/data/Products/Technical/A5076-1-SNOS.pdf
Notes: Compression on motor is 135-145 across all cylinders (stock longblock), 255 lph fuel pump, adjustable fuel pressure regulator, stock 19lb injectors.
Thanks for the input guys.
- Justin
blksn955.o
3,263
st.louis mo 314
Jul 26, 2007
  • Jul 26, 2007
That is a plate system...not so much a direct port.
I would not hesitate to get a plate setup like that actually. It keeps the fuel from having to travel the upper intake so it is VERY hard to get the "fuel drop off puddle issue". You can run a larger shot due to the lower intake that has generaly much straighter passages to the cyl.
A direct port will generally have a nozzle at each intake runner that has a line going to a distribution block...needless to say they are a bit complex in setting up and tuning over a plate or single nozzle setup.
P
4 Hole Bosch Injectors max HP and Tune -4.6 PI
  • Png1978
  • Jul 23, 2022
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Aug 10, 2022
Chipss36
Trick Flow Fuel Rail Installation
  • melzerkymsu
  • Oct 4, 2020
6K
Fox 5.0 Mustang Tech Nov 9, 2020
melzerkymsu
R
For Sale 2000 Mustang Turbo 6 speed
  • rdwyellowguy
  • May 28, 2020
3K
SN95 Mustangs For Sale (1994-04) Jun 5, 2020
rdwyellowguy
R
Progress Thread finishing touches on my stroker build
  • doobismaximus
  • Jul 2, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2021
nickyb
Fox (Newbie) on3 Turbo Kit 91 Fox body
  • Slow91
  • Nov 9, 2018
24K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 11, 2019
marcelo
