Disc Brakes
  • Thread starter Thread starter jhbus
  • Start date Start date May 23, 2005
J
jhbus
36
  • May 23, 2005
Ok everyone, I know this is an old question, but I can't seem to find the answer. I have a 67 Coupe with manual drum brakes. I'm converting to power front disc. I got the booster, master cylinder and valve from Master Power Brakes. I got the complete setup for the front discs off of a 72 Mustang. I know that I ned to change the tie rod end. Now my questions. What brake hoses would work the best? The hoses on the disc brake set up were cut, so I can;t compare them with what I have now. Should I just use '72 hoses? Will they connect up fine? Also, do I need to change anything else? Thanks.
Joe
degins
361
Texas
May 23, 2005
  • May 23, 2005
You must use hoses that have the correct fitting for the caliper, in this case the 72 ones. I don't believe you will need to adapt the other end to the hardline fitting of your 67.
Pbum5
515
Minneapolis, MN
May 23, 2005
  • May 23, 2005
If you are going to do a Drum to Disc swap in your 67 to an early 70’s style you might need 1/4 to 3/8 brake fittings as pictured. That’s what I needed for a 68/69 disc swap.
They are used to fit the stock hard lines to flex lines. I used Russell Stainless Flex hoses that connect to the calipers. You might want to look into stainless flex hoses because they cost the same or even less than stock hoses.
67coupestang
509
  • May 23, 2005
i used the 73 hoses on mine, but i dont remember using any adapter fittings and im too lazy to go the garage this second. i'm taking it out in a bit ill check in later
67coupestang
509
  • May 23, 2005
just kidding i checked no fittings. but i did run new lines to the block on both sides. they had the standard ends on them and they're screwed right to the rubber 73's
J
jhbus
36
  • May 24, 2005
Great, thanks for all of your input!
Joe
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Manual disc brakes
  • Butchd88
  • Feb 28, 2026
zookeeper
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:54 AM
keel
