discouraged
  • Thread starter Thread starter one2gamble
  • Start date Start date Aug 24, 2004
1 of 2 Next Last
one2gamble
902
Monterey
Aug 24, 2004
  • Aug 24, 2004
I am starting to get a little shaken....it seems as though right when I finish something up something else goes wrong. I just got my exhaust done and replaced all the power stearing hoses. I crank the motor and I can hear a nice loud tick tick tick tick tick....so I pull the valve cover off and everything looks ok, Im assuming its a lifter but Im not sure. My car really needed to be running and running well within a month but I dunno now. Well if it is a lifter I guess I might as well replace the cam also just so I feel there is some benefit of the down time.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Aug 24, 2004
  • Aug 24, 2004
Lol...
Don't get discouraged... I'm 99% sure what you have is an exhaust leak. Probably between the header and the head. An exhaust leak here can REALLY sound like a ticking lifter.
Double check that all of your bolts are tight... then check to make sure you didn't screw up the gasket.
O
Ozsum2
695
  • Aug 24, 2004
Probably just alifter like you think. Try a little tranny fluid in the oil and only let it idle for a minute or so. See if it cleans it up and change the oil. Might be clogged.
one2gamble
902
Monterey
Aug 24, 2004
  • Aug 24, 2004
how much is a little tranny fluid? Ill give both a try
65fast
38
Mt. Airy
Aug 24, 2004
  • Aug 24, 2004
I would take my bets on an exhaust leak too. I got one on my six the size of Rhode Island and it sounds like a few bad lifters.
O
Ozsum2
695
  • Aug 24, 2004
Drain a quart out, and put a quart of ATF in. Gumout actually make a product for this, and it smells like it is 99% desiel fuel. It will clean out the oil passages and desolve the gunk. Because it thins out the oil, they say don't run the engine past idle. The lifter may be collapssed which means it will have to be replaced. You can just do that instead of the whole 9 yards with the new cam if you like. Pull the intake. If it is a lifter and if it is starved for oil, the degunking may help.
one2gamble
902
Monterey
Aug 24, 2004
  • Aug 24, 2004
well its not the exhaust I just went through that...ill give the gumout or atf a try before I rip it apart
P
PONY XPRESS
143
  • Aug 24, 2004
Be careful, don't just change one lifter, you may wipe out the cam lobe. If you plan on keeping the car do it right. You can also use kerosene or marvel mystery oil to clean out the lifter.
67GTA-FB429
777
Tri-Cities, Wa
Aug 25, 2004
  • Aug 25, 2004
Before you try cleaning the lifter....do you have enough oil in the car? My wife's Rodeo sounded like it had a lifter going bad but come to find out she was 2.5 qts low.
O
Ozsum2
695
#10
  • Aug 25, 2004
  • #10
Mechanics and me, have been changing out lifter for decades. Just because a lifter goes bad doesn't mean you have to change the cam.
Max Power
1,774
St Paul
Aug 25, 2004
#11
  • Aug 25, 2004
  • #11
Oz is right. Breaking in one lifter is no different than a whole set. Odds of wiping a lobe are practically nil.
O
Ozsum2
695
#12
  • Aug 25, 2004
  • #12
one2gamble
902
Monterey
Aug 25, 2004
#13
  • Aug 25, 2004
  • #13
well those "tricks" didnt work so I guess I will replace it, my intake just came in so Im half way there already . It will take me a few days to get the lifter, is it ok to drive for the time being?
O
Ozsum2
695
#14
  • Aug 25, 2004
  • #14
Yes. Unless there is just an ungodly amount of slack, the pushrod and rocker arm should still be secure. Not too long though. I have changed push rods that were pointed on top from being loose too long.
P
PONY XPRESS
143
#15
  • Aug 25, 2004
  • #15
Got to disagree with you fellows on putting a new lifter on an old cam. Check with comp cam, etc. Not recommended. But each to his own.
one2gamble
902
Monterey
Aug 25, 2004
#16
  • Aug 25, 2004
  • #16
I think its the other way around pony...a new cam on an old lifter = bad idea.
P
PONY XPRESS
143
#17
  • Aug 26, 2004
  • #17
Let us know what the foot of the lifter looks like once you get it out. If there are any wear marks (grove or scratches) you'll need a cam.
O
Ozsum2
695
#18
  • Aug 26, 2004
  • #18
Folks, do you honestly think that every time one of this lifters went bad we put in a whole new set plus a cam? Get real. The cam guys are in business to MAKE money, not save you money.
Max Power
1,774
St Paul
Aug 26, 2004
#19
  • Aug 26, 2004
  • #19
Comp Cams offers a warranty. They have to be careful.
Look at a new cam lobe surface and look at a new lifter. It's primarily the cam your are breaking in, not the lifters. While lifters will get a pattern to a particular lobe, you can replace lifters in singles or in sets with no problem. The only thing you want to avoid is swapping lifters from bore to bore or using used lifters.
P
PONY XPRESS
143
#20
  • Aug 26, 2004
  • #20
one2gamble
What size engine?
How many miles on your engine?
What kind of oil are you using?
1 of 2 Next Last
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
M
Running rough
  • Mike3
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 1, 2026
Mike3
M
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
