  • 1994 - 1995 Specific Tech
Distributer Question
  • Thread starter Thread starter Synned
  • Start date Start date Jun 13, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Jun 13, 2005
  • Jun 13, 2005
Yesterday I went to clean around the engine bay so I removed the cap off the distributer, just the black plastic piece on top. I then removed one at a time and cleaned it, and put them back on as i took them off. I'm almost positive I did it correctly, but does anyone know where I can find a diagram of the correct plug setup because my car doesn't feel strong today. If one or two was switched it would run poorly correct? And that piece of plastic has nothing to do with it right? I'm trying to figure out why it isnt pulling at all today. It is very very humid and hot out, so maybe thats it also.
dstanggt50
1,316
Woodinville, WA
Jun 13, 2005
  • Jun 13, 2005
Are you talking about the firing order??
1,3,7,2,6,5,4,8
94-302-vert
1,947
NE CT
Jun 13, 2005
  • Jun 13, 2005
You removed your plug wires to clean the contact point between the wire and the distributor? It is possible that one of your wires got a bad connection from being pulled off...
Chris
Synned
Mar 31, 2005
991
Philly
Jun 13, 2005
  • Jun 13, 2005
Yes but how can I be 100% sure I put the right plug in the right spot?
dstanggt50
1,316
Woodinville, WA
Jun 13, 2005
  • Jun 13, 2005
there is a #1 marked on the cap, put the #1 wire on, and counterclockwise follow the firing order.
Synned
Mar 31, 2005
991
Philly
Jun 13, 2005
  • Jun 13, 2005
Thanks, seems like they're correct.
CManT1914
3,172
Killeen, Texas
Jun 13, 2005
  • Jun 13, 2005
When you pulled your cap off, did you get it back on right? Although it should only go on one way, it's best to make sure it's on right and clamped down good. I noticed my cap and bowl (I think it's called the bowl) was loose and could be pulled up about .5" from the bottom of the distributor. I pulled the cap off and the 2 screws inside had backed almost completely out. I tightened those back down, and actually the stang runs better now. It also gets less backfiring (maybe due to a better spark now since the points have better contact with the rotor). Check everything to make sure it's all tight. The plugs should click when seated on the points properly.
Also, I hate to scare you, but when I changed my plug wires, the next day my car started running real bad. I was stumped for a month as to what it was causing the problems. I had switched back to the original plug wires and everything. Ended up my MAF decided to take a crap on me at the same time. Talk about coincidence. Good luck
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
Looking for a high-res photo or scan of Rotunda EEC-IV Overlay #17 or #23
  • Smokinjoe 33
  • Jul 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2026
Praetorious
P
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Cleaning up Aluminum
  • limp
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2026
KRUISR
