Distributor gear problems...
Canimakeit
357W ina 89 25th an GT. TW heads 202/160 ported, Super victor intake, 585 lift 290dur comp cam with 15 firing order, MSD dizzy, hard ARP oil pump shaft, melling HV oil pump.
whew, Hbeam rods, JE pistons, stock crank. Internal Balance 28oz.
So, I put the motor in the car and broke it in with NO problems, none. Sound's AWESOME and runs awesome. I go through the valves one day, bumping the starter over to get each to TDC. After I do this I try to fire the car up and no oil pressure or fire, so, I pull the Dizzy *knew exactly what happened from experience.
Bare in mind that after break in* 3 days/ 3 20 minute runs* I adjust valves and thats ALL I did different, WHILE adjusting valves is when it happened.
I had JUST had it running before adjusting the valves and it was running perfect with PERFECT oil pressure, never misfired. This happened WHILE I was bumping the engine to get each cyl to TDC.
So, I got another distro gear from O'Reallys, install it, change oil AND filter. With drain plug out I poor a whole QT of motor oil in the valve cover AND in the distro hole.
Fired the car back up and sounds great again and ran for 5 minutes, took distro back out to check gear, its shined where its wearing already.
This is a FLAT TAPPET comp cam custom grind.
Is the HV oil pump doing this? wrong distro gear? clearance problems? This motor was put together by me and a good friend after a well known shop done the work. The distro its self is the MSD billet and doesn't have alot of play anywhere * no more then normal*
It did this both to the MSD and O'really gear.
Just hoping someone has a suggestion, it's been 7 long years since this car has been out and this is very frustrating. Trying to get back in the game.
The only thing that comes to mind is the same thing that you're considering, which is the distributor gear being incorrect. If you're running a flat tappet cam, you need the cast iron gear. The steel gear, which I'm assuming you may have on the MSD distributor, is meant for a roller cam. The pitch on the teeth are different, and fortunately, the teeth are harder on the cam gear vs. the distributor, so you should be pretty safe just swapping to a new gear. It's possible that there could be clearance issues, but it would likely be too much, causing the distributor to not fully seat. In some cases, material needs to be removed from the end of the shaft, where it engages the oil pump driveshaft, in order to allow the teeth to engage each other.
