Distributor Help. Wont Start
  • Thread starter Thread starter onefstsnake
  • Start date Start date Dec 22, 2006
onefstsnake
792
Northern VA
Dec 22, 2006
  • Dec 22, 2006
Well I got the Cobra intake on and everything hooked up as far as sensors and vacuum lines. I put the distributor back in just like I took it out.
So today I go to start it up and I let the pump cycle 20 times or so to fill the fuel rails.
I crank it and it cranks and sputters but never really starts. So I play with the timing a bit. Ok so now it sputters more but still doesnt really run. So I check the firing order and its good... Still wont start.
I turn the distributor a bit and I hear the fuel pump come on when I move it to a certain postition... WTF?
I tried starting it a few more times then I noticed the Negative battery cable was super hot.
Any Ideas???
onefstsnake
792
Northern VA
Dec 22, 2006
  • Dec 22, 2006
I did notice that the distributor hold down/clamp wasnt bolted on, but I doubt that would cause anything...
I dont think anything is hooked up wrong. And I know I put the distributor in correctly.
Its just odd that the fuel pump is cutting on when I rotate the distributor...
Also when removing the stock intake there was a metal bar that bolted to the upper and connected to the lower I believe. Im not sure what this is... Maybe a ground but I have an extra 4G grounding strap on the block...
89streetbeast
365
horton,ks
Dec 22, 2006
  • Dec 22, 2006
didnt pinch a wire in there somewhere maybe just a guess. that bar thing youre talkin bout, i have no clue what it was either when i swapped to the typhoon. didnt need it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 22, 2006
  • Dec 22, 2006
When in crank mode the fuel pump powers up, runs for a few seconds and cuts off. It stays off until the pip signal from the distributor tells the computer to turn it back on. That prevents the fuel pump from continuously running when you turn the ignition switch to the run position and leave it without the engine running. Turning the distributor causes the pip signal to activate the computer to turn on the fuel pump.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing. If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back in when you finish.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 18-Oct-2006 to include TFI fault during crank/run cycle
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
onefstsnake
792
Northern VA
Dec 22, 2006
  • Dec 22, 2006
well I had the distributor 180* off and the TPS wasnt getting signal.
IT was quite an explosive experience... Since the spark plugs werent firing right fuel was puddling up everywhere. Once I got the ignition right it fired up and bang bang bang... shooting flames out of both pipes. along with some old gasket material that I used on the header flanges...
but all is well now. Just need to adjust timing and probably replace the plugs.
HISSIN50
34
129
Dec 22, 2006
  • Dec 22, 2006
onefstsnake said:
IT was quite an explosive experience... and bang bang bang... shooting flames out of both pipes.
And your shorts from the sound of it.
Nice job by you and JR to get it whipped.
onefstsnake
792
Northern VA
Dec 22, 2006
  • Dec 22, 2006
yeah the front of my other car got sprayed with all sorts of crap that had gotten into the heads.
Car still feels rough but Im thinking the plugs are all gummed up and I havent put a timing light on it yet.
onefstsnake
792
Northern VA
Dec 23, 2006
  • Dec 23, 2006
well for some reason its blowing alot of white smoke through the exhaust...
I put a red shop towel over the pipe and the red towel turns purple...
I know its probably coolant, and I know some got down into the cylinders but not much. So how long should it take for the coolant to burn off? Ive had it running for ~10 min since I got the intake on.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 23, 2006
  • Dec 23, 2006
I would think if it was just a little in the cylinders it should burn off quite quickly. Perhaps you huge backfires blew a head gasket. And if you got coolant in your cylinders then it would be a good idea to change the oil since that coolant/water mixture is now in the oil.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 24, 2006
#10
  • Dec 24, 2006
  • #10
Always plan on changing the oil after any removal of the lower intake manifold. The coolant and gasket scraps drain into the bottom of the pan and need to be removed. Left in the oil, they will damage the engine or oil pump.
Top off the radiator with water/coolant, then run the car for 20-25minutes at idle. Take the cap off and watch the coolant level. It will be low and as the engine warms up, it will rise. Once it gets to its highest point, it will stablize. If the level drops, you have a leak. The coolant pumped out the exhaust will take some time to vaporize out. This is due to the fact that it takes a while to heat the whole exhaust system up past the boiling point of water. Shut the engine off every 5 minutes or so and check the oil level and oil appearance. Watch for a change in appearance and increase in oil level. Either one shows evidence of a coolant leak into the engine.
onefstsnake
792
Northern VA
Dec 24, 2006
#11
  • Dec 24, 2006
  • #11
thanks for all the great info.
jrichker you need to write a book. I know I would buy it.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • dan50
  • Jul 18, 2026
dan50
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
  • brandyn200
  • Jun 20, 2026
AeroCoupe
