  • 1994 - 1995 Specific Tech
distributor/timing question
  • Thread starter Thread starter 95BlueStallion
  • Start date Start date Jan 7, 2008
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Jan 7, 2008
  • Jan 7, 2008
So I had to loosen my distributor and pull it out a little to install my new intake, but as I went to retighten it in the end I accidentally rotated it slightly. I know where it was set from the factory as I made marking to revert to incase this happened, and the car is running great, but my question is this: I noticed the idle changed as the distributor was rotated back and forth. Is there a significant difference in timing by the rotation of the distributor only by a few degrees? Which direction of spin advances or retards the timing? And is this how some people advance their timing for performance reasons? When I tinkered with it, my car seemed to idle and rev crappy in any position but the stock one... Sorry, I know yall are probably rolling your eyes at me!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 7, 2008
  • Jan 7, 2008
Hello Nick
Honestly ... No rolling eyes on my part directed at you
I see your post as an inquiry for basic info
Yes ... just the slightest nudge in either direction can change your value
by 2 to 4 degrees
You need to get yourself a timing light so you can be in total control
of that setting :Word:
Yes ... twisting the dizzy is how some add more spark
but
The real cool cats ... They use a keyboard
Grady
95BlueStallion
5,130
3,103
214
Cedar Rapids, Iowa
Jan 9, 2008
  • Jan 9, 2008
Hey, thanks Grady. I didnt know how sensitive a change that made. I will have to get a timing light, cause all of a sudden my car wont hold a steady idle in the morning until it warms up... That is one thing I want to check is the timing. Im also kinda wondering about some vacuum lines I rerouted, but Ill figure it out either way.
95CobraMike
1,046
Lima OH
Jan 9, 2008
  • Jan 9, 2008
ya I.d check vaccum lines also..... timing a few degrees usually doesn't effect the idle speed... but it could happen.. get a timing light.. they are pretty cheap and worth the investment
toyman
1,944
54
79
Vernon BC
Jan 9, 2008
  • Jan 9, 2008
Just remember to remove the "SPOUT" before you test or change the setting
Located between the airbox and the fender
HISSIN50
34
129
Jan 9, 2008
  • Jan 9, 2008
I have different experience about a small change in timing noticably changing the idle speed (atleast in my experience on much more stockish cars than Mike's nice combo. ). I can hear the idle drop (and note it with a digital tach) with as little as a 2* change (advancing raises the idle, retarding lowers it).
95CobraMike
1,046
Lima OH
Jan 12, 2008
  • Jan 12, 2008
95BlueStallion
5,130
3,103
214
Cedar Rapids, Iowa
Jan 12, 2008
  • Jan 12, 2008
So I was at the parts store getting a dang belt tensioner cause mine went to flappin around and I looked at timing lights. The basic was like $30, and the "digital" was $125. Is there any reason why I would be wrong in getting the basic one, since Im not an engine builder or dyno tuner? Im still curious about my timing... Im one of those guys that always wonders if I messed something up, even though it seems right...
HISSIN50
34
129
Jan 12, 2008
  • Jan 12, 2008
I'd get the cheap one. The bottom line is that we tune by ear (if we hear pinging, we retard the timing). Ergo, the timing light is just to get us close and to compare our setting to that of other folks.
95BlueStallion
5,130
3,103
214
Cedar Rapids, Iowa
Jan 12, 2008
#10
  • Jan 12, 2008
  • #10
Thank you, sir.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Fox Possible timing not sure
  • K1tha1
  • Apr 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2025
AeroCoupe
