  • SN95 4.6L Mustang Tech
do i need a new fuel pump?
  • Thread starter Thread starter pdstang2000
  • Start date Start date Jul 9, 2008
P
pdstang2000
17
  • Jul 9, 2008
hey all,
so my car gives out under WOT at bout 4000rpm. i hooked up my predator and checked the FRP as i drove, and when it cuts out my FRP goes from 40psi to bout 7 psi.... is it my injectors, tune, or pump? could this be the cause of my random misfire code that keeps popping up?
when motor built 24 lb injectors were put in... motor is a 4.6 stroked to a 302 at 9.2:1 compression, stage 2 cams and heads, trickflow intake, headers, cai, bolt ons... making bout 315rwhp and 316rwtq...
mogs01gt
3,113
30
119
Ohio
Jul 9, 2008
  • Jul 9, 2008
I would recommend a new pump. The Focus pump should help out but I dont see why its dropping down to 7psi, that leads me to believe there are other issues going on.
Stark77
501
Tallahassee, FL
Jul 9, 2008
  • Jul 9, 2008
with Stage 2 cams and stage 2 heads you're running a stock fuel pump and only 24lb injectors?
Stan Weiss
347
Philadelphia, PA
Jul 9, 2008
  • Jul 9, 2008
24lb injectors should be good for 365 HP at 95% duty cycle and .5 BSFC
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
P1237 fuel pump secondary circuit fault
  • Project_2v_
  • Mar 27, 2023
4K
SN95 4.6L Mustang Tech Mar 30, 2023
alwayshi
A
