Tried doing a search. But my clutch somehow bit the dust in 10k miles. I had a new motor and clutch put in under warranty at 50k miles. I find it hard to believe I tore through a clutch when I babied it for the first thousand miles and then haven't beat on it at all since. Not a single burnout. I tend to think they're a waste of rubber. Anyways, I'm looking at the Ford Racing 96-02 Mustang "King Cobra"Clutch,Pressure Plate,TOB. from mustangtuning.com Can I buy just that? It's for my 98 gt convertible. All I have are a magnaflow catted x-pipe and a magnaflow "magnapack" catback. No plans to upgrade anything else for a while, unless something breaks. At the bottom of the description it says: "Requires metric pressure plate bolt N602549-S51M and alignment dowel pins D1FZ-6397-B." What does that mean?
Thanks in advance,
Joe
Thanks in advance,
Joe
I would definately have the flywheel cleaned up and you shouldnt need the dowels or bolts. You only need the dowels if your getting a new flywheel and the 6 pressure plate bolts should be reuseable. Resurface your flywheel unless you want another new clutch in 10k....
