Do I need my EGR?
dec322
401
Bham AL
I just replaced the injectors on my car and noticed the egr doesn't have a tube running into it. There is a place for a tube but its gone. The smog equippment has been deleted.
Also, I found a hose that the previous owner had tucked away under the intake. I don't know where it goes.....One end is connected to the "canister" (looks to have two chambers) behind the passenger side headlight....the other end is just flapping around.
EGR and the smog pump are 2 dif systems. The egr gasses are routed internally through the stock intake manifold; no external tubes are needed.
There is no power gain to be found by removing the egr, and possible economy losses and part throttle drivieability issues can result.
It sounds like some modification of the fuel evap can system was done by the previous owner. That cannister is filled with carbon, similar to what is used in fish tank filters. This can catches fuel vapors from the fuel tank, and stores them in the carbon until the motor is running. When the motor starts the vapors are purged from the can, and burned in the intake charge. I don't beleive the stock system had the outlet from the can routed directly to the intake. It should have run to the intake box?
jason
jason
Hmm....so there isn't supposed to be any tubes going into the egr? Thats fine with me.
Well, it doesn't go directly into the intake. He just had the end of the tube hidden under the intake (right above the fuel injectors on the driver side). So, I'm just look for the source (unless the canister is the source, in which I'll be looking for where the tube should end).
There is a vacuum line that goes to the EGR valve. It has a 90* elbow on it and the line comes from the passengers side fender. Behind the strut tower.
Ok....thanks for the picture. I'll check that out tomorrow.
I saw a place on the bottom of the intake (driver side) for a vacuum line. The previous owner has capped it off. I'll have to get a longer line b/c the one that is not connected is too short now.
I ran the car for a while without the EGR hose connected and didnt notice much if anything...
Make sure you get a nice rubber line, since the stock Ford stuff is hard plastic junk...
90% of my vacuum lines have shattered... :notnice:
Yeah, the car runs pretty good. Every now and then I get a little bit of a surging idle. I've have yet to really look for it so maybe as I fix these little things, I will accidently fix the surge.
Note Richker/Moss' diagram -- it's not a VACUUM hose that goes to the egr valve; a vacuum hose goes to the EVR (EGR valve regulator); a hose then runs from the OUTPUT PORT of the EVR to the EGR valve; the ecu determines when vacuum is delivered to the EGR valve by actuating the EVR.
